Thread: Filling the crack - what to use silicone or?
    TeamNelson's Avatar
    Feb 2013
    Tucson (Marana) AZ
    48
    My crack: expansion joint between the pool deck and the coping ( the stone immediately surrounding the pool) This is the area needed to fill this crack above my tile below the coping...? After putting in a filler to bring the expansion joint within 1/2" several other posts use polyurethane products. A pool service tech recommend Boss Silicone - any experience as to this product? Would it be any better to use a marine grade product like 3M 5200 fast cure sealant on my application. Being in AZ with more swim season & heat than the average- will silicone based products provide the best waterproof & flexible seal?
    12/2012; 16K Gal. IG PebbleTec, Pool w/Spa attached, Pump Sta-Rite IntelliPro 4speed VS 3050 160gpm, Cartridge Filters Sta-Rite S8M150 450SqFt, Pentair IC60 SWCG, Turbo System 20 In Floor PopUp Heads Cleaner, Zodiac Auto Cover, Pentair EasyTouch 8 Controls & Screen Logic Interface w/APP for phone remote access, InterFab Slide, FiberOptic perimeter lites, TestKit TF100!!! The BEST & the Taylor Speed Stir - A MUST HAVE!!!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: Filling the crack - what to use silicone or?
    Polyurethane caulk is the best product. Sikaflex is the brand of choice for my PB. Another member recently discovered this product, NovaLink SL, which looks promising also. But, I haven't seen any real world analysis of its performance. But, I am considering trying it next time.
    30,414
    +1 what pooldv said. As an aside, self leveling polyurethane is very tempting but I found it incredibly difficult to use.
    I would say to say with a non-leveling polyurethane.....Sikaflex is very commonly used but there are several other brands.
