Thread: Brass eyeball returns worn out
    Aug 2015
    Topeka, kansas
    8
    i have an in-ground pool with stainless steel walls installed in 1964 I (believe by Inertol Co, LLC) and it has brass eyeball returns that need replaced. The brass nuts will no longer stay screwed on. Anyone know what is needed?
    25,000 gal concrete bottom with stainless steel sides 1 HP Super Pump, Sand Filter, Robot automatic cleaner
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Brass eyeball returns worn out
    Can you change them to plastic eye's? are they the same thread? is the pipe also brass?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    That sounds like a cool, old pool! I have never heard of that before. Pics! Maybe check with INYO Pools.
