Results 1 to 20 of 20
Thread: How to remove and clean a hayward t-cell-15
    May 2015
    Austin, TX
    118
    I searched for cleaning procedure here, could not find. Can someone point me to it? I am going to be doing it for the first time
    15K gal, IG (I think its Vinyl not sure), 2 HP WhisperFlo pump, 60 sqft Pentair DE filter, SWG Hayward Aqua rite controller with t-cell-15, Aqualink RS6, Jandy Spa side 4-button, Polaris 280, 400K Pentair Minimax NT Heater Propane, test kit TF100
    Jun 2011
    Long Beach, CA
    2,784
    Re: How to remove and clean a hayward t-cell-15
    Have you removed the cell yet? To remove it you need to have the pool turned off and just unscrew the two unions on the cell housing.
    If it doesn't have any scale on it, don't clean it. Usually if there is just a bit of scaling then it is best to use a wooden object such as chop sticks to remove the scale. Every time that a cell is acid washed you will reduce its lifespan as the acid wears off the coatings on the cell plates. If you do have to use acid, use a ratio of 4 parts water to 1 part acid.
    In almost six years of using a SWG I have only acid washed the cells a couple of times and that was when the cells were actually dying.
    May 2015
    Austin, TX
    118
    Quote Originally Posted by ping View Post
    I havent removed the cell yet. The 'check salt' and 'inspect cell' lights are flashing. Its showing salt level of 2700. This is a 15000 gallon pool. I just added a 40 lb bag of salt. Waiting to see if that helps. I thought of cleaning the cell because it says on the cell, theres a sticker, inspect and clean every 3 months. This is a new cell installed 6 months ago.
    The salt at 2700 will give a check salt warning. Raising the salt to above 2700 should solve that. The check cell flashing light is just a timer that flashes a reminder. Clear by pressing the diagnostic button for about 5 seconds.
    Support the site
    May 2015
    Austin, TX
    118
    After two 40 pound bags of salt, the reading still shows 2700 and the check salt light is flashing red. I was able to make the inspect cell light go away by press and hold diagnostic button. Whats the best next step ? Should i add more salt ? I dont have an alternate method to measure salt, its 98 degrees in austin
    May 2015
    Austin, TX
    118
    Another question , the unit inside my bedroom used to display the salt level earlier, its no longer doing that. Maybe something changed after the installation of new cell and salt system circuit board. How do i make it display that metric again
    Mar 2015
    Cantonment, FL (Pensacola Area)
    380
    Resetting or re-calibrating the controller may help. What controller are you using and can you check the instant salt reading?
    Scott
    15,000 Gallons vinyl in-ground screen enclosed, Hayward Eco-star SP3400VSP, Hayward Aqua Logic PL-Plus, Hayward T-15 Salt Cell, Hayward S244T Sand Filter, Polaris 380 with booster pump, Hayward heat pump HP50HA. K-2006 kit.
    May 2015
    Austin, TX
    118
    How do i determine my controller type ? How do i check instant salt reading ?
    Mar 2015
    380
    Aqua Rite I think is what comes with just the SWG package, or could be an Aqua Logic for that and other controls.
    Here's the Aqua Rite How To Recalibrate the Salt Level on a Hayward Aqua Rite - INYOPools.com
    Aqua Logic (most versions) page 14 here: http://www.haywardflowcontrol.com/pd...iagnostics.pdf
    Scott
    May 2015
    Austin, TX
    118
    My controller matches with the first link you sent. Hayward aqua rite. I followed the steps to recalibrate the level, it failed after step two. Pressing the diagnostics button 5 times did not cause the expected number countdown. I tried it several times and no joy
    Jul 2014
    Hope Mills, NC
    567
    What numbers display when you press the button, record all of them for us to see. My best guess is you caught the SWG during an OFF period and it doesn't show a value for instant salt reading when it is not generating.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    May 2015
    Austin, TX
    118
    Here are the numbers . It shows 2700 . I move switch to off position. Then move it back to auto with filter pump running. Then i press the diagnostics button 5 times.
    2700
    90
    26.4
    6.05
    97P
    -2700
    Your salt is still too low or your cell is going bad. How old is the cell? You definitely need to get a good salt test kit, such as the Taylor K-1766.
    Support the site
    May 2015
    Austin, TX
    118
    This salt cell has been replaced 6 months ago. I had added 80 lbs of salt just last week. I will add another 40 pound bag and see
    Jun 2011
    Long Beach, CA
    2,784
    You should always test the water's salinity before adding any salt when you are questioning the cell.
    What is the software revision number? It should be in the diagnostic readings.
    Are you sure that the cell is a t-15?
    You definitely need to get a good salt test kit.
    Is your water temperature really 90 f? If it is, keep the salt at 2800 to 3000. How warm will the water get?
    Do you have a working main drain? If not, you might have salt sitting on the bottom of the pool. Try brushing the pool completely including the wall and entire floor.
    Support the site
    Jul 2016
    Staten Island NY
    1
    Quote Originally Posted by Sal512 View Post
    If you need to remove it you can find tutorials on YouTube . I just cleaned mine following the tutorials , although for me the acid didn't do much but then I soaked it in 5% white vinegar (somebody on YouTube recommended it ) and it cleaned the cell perfectly. I did a thorough rinse , installed it and finally inspect cell light is off and generating light is on .Good luck !
    May 2015
    Austin, TX
    118
    I added more salt and now the check salt light has gone and generating light is on. Yes, i have confirmed that it is a t15 cell. And the pool temp is 90, its austin texas peak summer. I can check for the software version, is it something that looks like r 1.56? I purchased the t100 test kit already after reading on this site. Are you saying i need a different one if i have a salt pool ?
    Jul 2015
    OV, CA
    65
    ... The 'check salt' and 'inspect cell' lights are flashing. Its showing salt level of 2700. ...This is a new cell installed 6 months ago.
    Aquarite controllers will flash the "Inspect Cell" every 500 hrs of operation as a reminder to inspect the cell. To clear the message you press the diag button for three seconds to reset the reminder timer. So you will see that indicator again.
    20K IG gunite with attached spa, dark plaster and lava rock waterfall, very 90's. Pool equip refit in 2005 with all Sta-Rite cartridge filter, pump, and heater; Polaris sweep; Goldline Controller(Hayward) with T-Cell-15 SWG
  20. Back To Top    #20
    May 2015
    Austin, TX
    118
    In my case the inspect cell is turning on within 24 hrs after i reset it by pressing and holding the diagnostics button. Does this mean, my cell really needs an inspection right away
