Results 1 to 12 of 12
Thread: Adding DE to sand filter
    I decided to try adding some DE to my sand filter to try and improve my clarity a bit more. I should have added it more gradually but I eyeballed it. After a few minutes I checked filter pressure and it was up just a bit more than 1psi (19psi->20.5) so I thought I was golden. I just checked 3 hours later and pressure is up about 4-5psi (24psi). Any risk in damaging my pump or filter system with that much pressure rise?
    26K gal, vinyl, 1.5 HP pump, 18" sand filter, Goldline Aqua Rite SWG, Dolphin Diagnostic cleaning robot
    Re: Adding DE to sand filter
    Is it possible that the additional rise in pressure is due to the filter catching a lot of the finer debris that the sand alone was missing?
    IG ~15,000 Gallon Plaster Pool with Attached Spa
    Hayward SwimClear C4025 - 150GPM, Cartridge
    2hp Pump 1.1 Service Rating
    Direct sunlight most of the day
    Jan 2009
    Cupertino, CA
    1,966
    4-5 psi should not be harmful. When do you backwash normally?
    --paulr
    BBB "Intermediate Swimmer"
    I woke this AM and walked out to the pool. WOW. The DE had really helped. Water was glass all the way to the bottom.
    However, i realized that the jets were just bubbling a tiny bit and little water was coming out. I went out to the pump
    and pressure was up near 28psi, condensation in the pressure gauge (it rained last night), and the pump was not pumping
    much. I have had a small intermittent pressure leak at my filter that occassionaly will allow some air/water out the backwash
    port if the valve mechanism does not seal well. I think the added pressure causes the leak to come back and get slightly worse.
    I think I need to replace a seal in the filter. I decided to backwash the DE out, and the pump went back to the old pressure.
    Probably some of the better clarity in the pool was due to jets not moving the water, but I still think the DE made
    a noticable difference. As for backwashing, I had a pretty bad pool starting the season, so I was backwashing every
    day for a about a week. Then I went to every few days. Now I am at about 2-3weeks
    Additionally, one of my 3 jets seems to have a decent amount of air (bubbles/fizz) in the water stream, even when my pump is holding at 19psi.
    Hunting this down is on my to-do list.
    All in all I am happy with the DE experiment but I need to hunt down some leaks before I do again.
    you can add de to a sand filter?
    Above ground 33 ft round 52 in. high
    Approx. 25000 gallons
    Hayward Dreamline Sand filter holds 250lbs sand
    Hayward CL-200 chlorinator
    Hayward 1.5 hp 67 GPM pump
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    yup...instructions are in pool school...just a little is all you need
    May 2008
    ottawa, canada
    11
    Last night I also added DE to improve the water clarity. I put in enough to raise the pressure from 7 to 8 psi, (1 3/4 cups). After about 4-5 hours, the pressure was up to 15 psi. I decided to backwash before I went to bed as I wasn't sure how how the pressure might go overnight. The water was uber clear, the next morning. I suspect that my sand is a little old(5 years).
    I would add something to the Pool School, that says, it is normal to see PSI rise, as the filter scrubs more particles out of the water, but to be careful as the PSI may be become excessive in short order.
    20x40 vinyl IGP(120,000 L), with Intelliflow VF Pump.
    17 boxes of Enersol Solar panels,
    Hayward Sand filter, Polaris(Auto-Clear) SWG,
    That is a good idea. I updated the Pool School article.
    Jul 2012
    Winter Haven, FL
    103
    Sorry to bring back a dead topic, but I am doing this now. Pressure has went up 8 psi, gonna do a backwash before bed as well to relieve some psi, it has to be sucking up all of the pine particles the sand wasn't.
    16x32 27k gal oval gunite pool, 24-inch Hayward sand filter, 1HP pump
    Does the DE need replaced with each backwash?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Quote Originally Posted by TheGrouch
    Yes.
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Yes.
    Edit: Darn Richard, you love doing that don't you!!!!
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
