Thread: help with texas heat
    Jun 2016
    teague,tx
    8
    Hey i need some advice ive looked everywhere but cant seem to find what the best ranges for my pool should be. I need to know what my cya and chlorine level should be when dealing with this kinda heat. I live in central texas and it is 97 and up everyday with the heat index its always over 100 daily. I kniw the range for cya is 30 to 50 and i know where the chart is to show me what chlorine level should be to match up with cya but in these extreme temps what would u say is the cya level i should try to stay at i started off with 30 and it doesnt seem like it protects my chlorine now ive uped it to 40 and i will start off the morni g with 5 by the time i get home from work its at 1 please help if u can thanks
    Also my water is not green in fact pool looks very nice but the daily loss of chlorine is killing me im having to pour a whole bottle of bleach in everyday just to keep up with the heat
    16x32x52 rectangular vinyl above ground 15000gal
    2hp hayward proflow pump sandfilter
    Ph 7.2
    Ta 60
    Cya 40 FC 5. CC. .5. TC. 5.5
    Jun 2014
    15,121
    Re: help with texas heat
    As long as you are sure your pool is algae-free and your FC loss is due to sun loss, you can raise that CYA up a little higher. My CYA is currently at 60-70 to help fight-off that intense sun UV. Therefore I keep my FC between 6-8, sometimes bump it up to 9 if there's a heavy swim day ahead. Hope that helps.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    Yep---------60 CYA and adjust FC accordingly. I still lose 4 ppm daily.
