Thread: question about TF-100 Test Kit
    Jun 2016
    uxbridge, ma.
    4
    Cool question about TF-100 Test Kit
    Hello........
    I think I have an easy question to ask (but, obviously still too complicated for me ....... I just received my TF-100 Test Kit and was reading the material.
    Under "Weekly Tests (or as needed)", it says in step 2 of the Chlorine Drop Test to "add one heaping scoop of the R-0870 powder" ...... then says the exact amount is not important. The container of R-0870 powder is 10 grams ....... can someone how they measure out a proper amount for a test??
    Thanks so much,
    Paul L.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,559
    Re: question about TF-100 Test Kit
    Paul, Here ya go. Hold the blue spoon by the flat end. Dip it into the power with out dumping or leveling any of the powder out. The powder should be slightly rounded on the top.
    If you KNOW you have FC in the water and it turns pink you added enough. IF it does not turn pink then add some more powder.
    How are the other tests going?
    Kim
    Jun 2016
    uxbridge, ma.
    4
    Hi Kim.......
    Thank you......the kit doesn't say anything about that scoop.....I didn't even see it until you mentioned it and I went looking for it.
    I haven't performed any tests with the kit yet......I had just opened it and was reading the material.........I feel like a little kid with his first chemistry set......I can't wait to start testing
    Thanks again
    Paul
    Jul 2012
    Tallahassee, FL
    30,559
    That DOES make sense then. If you do not see the little scoop you would NOT know how much to add. Glad I could help!
    Kim
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    Quote Originally Posted by paull View Post
    Paul
    I've noticed over the last couple of years that this is the first step of becoming a pool snob. Welcome to the club!
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
