Results 1 to 14 of 14
Thread: FC loss
    Jun 2016
    victorville ca
    16
    FC loss
    9 am test results:
    FC 3
    cc 0
    ph 7.4
    TA 100
    ch 125
    cya 30
    4:45 test results:
    FC .5
    cc .5
    ph 7.4
    TA 100
    ch 125
    cya 30
    I checked overnight loss last two nights and it has been 0. How should I proceed to keep my FC levels around 4 and not get to 0 before the end of the day? Full sun, 105 temps, swimmer load (6 kids, averaging 4-6 hours a day).
    15 x 42, 4600 gal, AG summer waves, vinyl, SkimmerPlus 1000 filter pump, K-2006
    Jun 2014
    15,221
    Re: FC loss
    As long as you are algae-free, which it sounds like you are because you passed the OCLT and have less than 0.5 CC (clear water too right?), then increase your CYA. It must be hot there in V-ville, so I would increase CYA to at least 50. But make sure to increase your FC along with it - target FC of 6 and NEVER below 4. Your FC should hold much better.
    Hope that helps.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: FC loss
    You may have to jack up FC 2 points above target level too. I do.
    Jun 2016
    victorville ca
    16
    Re: FC loss
    The water gets a bit cloudy by the end of the day but is clear in the morning. I have a venturi style vac which doesn't get the fine dirt just stirs it into the water. The pump isn't greatest either but working on getting an upgrade. I will bump up my cya and fc as suggested and let you know how it turns out. Thanks!
    Aug 2015
    Ellis County, TX
    32
    Re: FC loss
    Does a CC level of 0 necessarily mean no algae is present?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: FC loss
    No, it does not.
    Aug 2014
    Northern IL
    4,615
    Re: FC loss
    If you passed the OCLT on the 1st, and it is cloudy now at times, try another OCLT. Then you will know. Also, you may want to test and add at night until you get to know your pool's habits better.
    Jun 2016
    victorville ca
    16
    Re: FC loss
    I added CYA to bump it to 40 on 7/1, finally got test to read 40 on 7/3. Seemed to keep the FC loss to 2-3 a day. Yesterday kids said pool felt slimy on bottom. I decided to bump FC to 8 from 6. There isn't any cloudiness today. I did OCLT test last night. No loss of FC. So, no cc doesn't mean no algae. Is there anything else I need to look at again?
    Last night tested chlorine 1 HR after adding 14 oz 8.25% chlorine to bump from 6 to 8, results:
    FC 8
    CC .5
    This morning:
    FC 8
    CC 0
    PH 7.4
    ph 7.4
    TA 100
    ch 125
    DFW, TX
    24,509
    Re: FC loss
    If your daily FC usage seems higher than normal or you suspect algae then you can do the Overnight Chlorine Loss Test to see if there is something cooking in there.
    Aug 2014
    Northern IL
    4,615
    Re: FC loss
    Is the bottom still "slimy"?
    Jun 2016
    victorville ca
    16
    Re: FC loss
    There seems to be a spot or two. I scrubbed them up. I will do another OCLT again tonight but last night there was no FC loss and no CC with this mornings test.
    Aug 2014
    Northern IL
    4,615
    Re: FC loss
    "Slimy" is a very good indicator of nascent algae.
    Glad you brushed and are doing another OCLT. Good luck!!!!
    Jun 2016
    victorville ca
    16
    Re: FC loss
    Last night test chlorine only
    FC 3.5
    CC 0
    This morning:
    FC 3
    CC 0
    PH 7.8
    Aug 2014
    Northern IL
    4,615
    Re: FC loss
    You should be good to go then!
