Results 1 to 14 of 14
Thread: Circupool SJor RJ?
    Jan 2015
    San Jose, CA
    232
    Circupool SJor RJ?
    Seems like a lot of you guys are using the RJ series rather than the SJ... is there any reason why I would NEED/WANT the RJ series to justify spending an extra $300?
    SF Bay
    ********20,000 gallon IG Fiberglass, DE Filter, Hayward Max-Flo VS, Taylor TF-100 Test, Circupool RJ-45********
    Jun 2011
    Long Beach, CA
    2,484
    Re: Circupool SJor RJ?
    The SJ has a basic controller and the output can only be adjusted in 20% increments. The RJ has a more advanced controller and they also offer the RJ+ which has a cell that should last longer than the RJ cells.
    Which size are you thinking of getting?
    Jan 2015
    San Jose, CA
    232
    Quote Originally Posted by ping View Post
    I'm looking at the SJ-40. I saw the RJ+ which is an additional $100
    The SJ-40 is $750 on Amazon at the moment. The RJ45 is $1100 and the RJ45+ is $1200
    or a Compu pool for CPX48 for $800 which is for a 60k pool then i'll have the extended life as well but not the 5 year warranty, only 2.
    SF Bay
    You should check out these.
    CaliMar Titanium Edition Salt Chlorine Generator for Inground Pools | Up to 60,000 Gallons | 7-Year Warranty | CMARSCT60-7Y
    Its a rebranded circupool but cheaper. Seems like a great deal. I wish i saw this before i bought mine from circupool.
    May 2008
    Long Island, NY
    145
    Pool Details: 25,440 Gal IG Vinyl 21x40 Mountain Pond (Graphex)
    Filter: Hayward Micro-Clear DE (48 Sq Ft)
    Pump: Hayward SP2603VSP VS Super Pump
    SWG: Circupool Si45
    Cleaner: Pentair Kreepy Krauly Prowler 820
    Jun 2011
    Long Beach, CA
    2,484
    Stay away from CompuPool products.
    You will have a lot more control with the CircuPool RJ or RJ+ units over the SJ's.
    bobodaclown's Avatar
    Apr 2011
    Lakeland, FL
    2,338
    It looks like the Calimar Titanium Editions are made by Compupool, in a Circupool housing, with transformer/main board as the same in the CPX/CPSC series.
    17K Kidney Shaped Pool Concrete (Diamond Bright) Pool, 3/4 hp 2 speed 115V Sta-rite Duraglas PEA5D-180L/P2R5D-181L (Impeller C105-92PS Diffuser C1-216P), 1.5 piping, Pentair CC100 Filter , Heat Siphon 100K BTU Heat Pump Pool Heater, Flow meter Blue White Flowmeter Model No. F-30150P, Hayward Astrolight SP0581N, SWCG CalimarTitanium Edition TE45 , Dolphin Nautilus Plus with CleverClean, Lakeland Florida
    Jan 2015
    San Jose, CA
    232
    Quote Originally Posted by bobodaclown View Post
    And everything I'm reading says run the other way.
    I thought compupool made the circupool also.
    Mar 2016
    New Albany, Mississippi
    134
    circupool and compupool used to be affiliated. Not anymore. since the split, circupool's reputation and product seems to have gone way up, while compupool's has stayed very low.
    lots of good reviews about circupool products on here. read them. all SWG have pros and cons. only your situation and research can help you know whats right for you.
    Apr 2011
    Lakeland, FL
    2,338
    Quote Originally Posted by wmmallette View Post
    The RJ-g series may be still affiliated with Compupool. Calimar Titanium edition by Compupool looks like the Circupool unit, may have different internals/transformer unit. Looks like the RJ series have two different versions one with a flow switch and one without.
    Quote Originally Posted by mmirav View Post
    Sent from my SM-G900V using Tapatalk
    They look the same as on the circupool website. I have the older rj45 model. Ive had a few problems but were addressed with warranty. It doesnt seem to produce as much chlorine as they state but im still satisfied with it. Probably would have bought the rj60.
    That is correct! CircuPool severed the relationship with CompuPool in the fall of 2012, four years ago! Please do not confuse the two companies.
    Don Uhle, Discount Salt Pool
    Jan 2015
    San Jose, CA
    232
    FWIW: I ended up with an RJ45 for my 20k gallon pool. I have it running @ 25% and have no problem maintaining clear water @ about 4ppm FC.
    At 50% I went into shock level in 3 weeks.
    SF Bay
