Thread: Can my Pool be Crystal Clear and have Algae in it?
    Jun 2016
    Center moriches
    23
    Don't know if I need to SLAM my pool or just need to raise the CYA level. I have a 24,000 gallon salt pool and have a current CYA of 45. I shocked my pool 3 days ago with 3lbs of granular and 2 days ago with 4lbs. I ran my SWG at super boost for 48 hrs, but my FC level is at 0. Even when I opened my pool it was pretty clear, not green. I power vacc'd everything out, water is crystal clear, but not getting an FC reading. My CC is at .4. My pool is exposed to direct sunlight all day, so Im thinking the sun is burning out the FC. I'm curious if I could have Algae in my pool even though it's clear. Hoping I don't need to SLAM it, but just shock it and add stabilizer.
    Jun 2016
    Center moriches
    23
    Re: Can my Pool be Crystal Clear and have Algae in it?
    SWG is a brand new intellichlor and all lights are green
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,278
    You can answer your question by doing an Overnight Chlorine Loss Test (OCLT) which is described: Pool School - Perform the Overnight FC Loss Test (OCLT)
    Take your FC to 5 or more with liquid chlorine early evening. Set your pump to run overnight, with the SWC turned off. Sample after an hour of mixing (just FC and CC). Test again just before sunrise.
    And welcome to TFP! Good to have you here. Please add your pool info as a signature. This is described in "Read before posting" (linked in my signature below.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Yes, last summer my water was crystal clear, my CCs were 0 and I had algae and had to SLAM.
