Results 1 to 12 of 12
Thread: Newbie
    Jun 2016
    Cleveland
    5
    Newbie
    I got the Taylor test kit and want to post my results and let's see what I need to learn next.
    TA 75ppm
    pH 7.8
    Cya. 55-60ppm
    CH 100 ppm
    FC 3.5
    CC .5
    The water looks cloudy green with some visible algae that I keep brushing. About a week of green. Unsure how much liquid chlorine to add! Pool math said 15 oz, but will that kill the algae?
    I have borates in there from previous borax additions but my Taylor doesn't test for that.
    Thanks for opinions and suggestions!
    9500 gallon IG vinyl liner pool, hayward sand filter.
    Jun 2014
    15,070
    Re: Newbie
    Hello and welcome to TFP! Got algae? ... SLAM (link below). With a CYA rounded-up to 60, your SLAM FC level is 24. Just make sure to lower your pH FIRST to about 7.2 before raising the FC. Make sure to follow all the other instructions on the SLAM page and you should do fine. Good luck!
    Also, to save on reagents, test FC with a 10ml sample, one heaping scoop of powder, and take number of drops and divide by 2. Example: 16 drops = FC of 8.
    Jun 2016
    Cleveland
    5
    Re: Newbie
    I did what you said and lowered the ph- I had never considered that before because 7.8 is the high end of the recommended range, right? Maybe that's why my algae kept coming back..
    Now I have but one bottle of chlorine test reagent from the Taylor kit, so should I wait awhile after slam to test so I won't need as many drops? I started to test during slam after adding 121oz bleach and realized it's going to get the tests used up fast.
    Jun 2016
    Cleveland
    5
    Re: Newbie
    Retested tonight.
    Alkalinity 60ppm
    pH 7.5-7.6
    FC 14
    CC .6
    What next, adjust alkalinity or continue with chlorine?
    What lowered my alkalinity?
    It was a very sunny hot 95 degree day.
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,237
    Re: Newbie
    Welcome! Good to have you hear
    Pat is dead on. Follow the SLAM article to the letter. It will take multiple days to complete. Only test FC while doing the SLAM, and occasionally CC so we'll see what's happening in the water. The M in SLAM is Maintain, Maintain, Maintain.
    Pool School - SLAM - Shock Level And Maintain
    After you annihilate the algae, it will get way easy to care for your pool, and the water will look amazing.
    Ignore the rest of the water chemistry for now (TA, pH etc.) that will all get adjusted after the SLAM.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Jun 2016
    Cleveland
    5
    Re: Newbie
    Thank you guys so much for the quick response! I wanted to fix it more before bed , I added a bit of baking soda while waiting on the response so I hope that doesn't mess it up.
    Is it safe to let kids swim in there during slam as long as the water LOOKS pretty clear?
    Joey316g's Avatar
    Jun 2016
    Williamstown, NJ
    41
    Re: Newbie
    Based on you CYA, I would ad at least another gallon of bleach. At your CYA, your shock level should be maintained at 24 FC. Don't worry about the alkalinity and ph right now as the tests are not reliable at high FC readings
    22,000 gal Cardinal Oasis 36x18 IG Vinyl
    Pentair IC40 SWG Sand Filter 1 1/2Hp Superflo pump Single Speed 3450 RPM
    Build date 9/25/15
    Taylor K-2006 with Salinity
    City water for fill
    Mod Squad pooldv's Avatar
    DFW, TX
    24,484
    Re: Newbie
    It is safe to swim when
    FC is above minimum and up to shock level for your CYA, FC/CYA Chart
    PH is between 7.2 and 7.8
    The water is clear, can you see the bottom?
    Then swim!
    needsajet's Avatar
    Jan 2016
    4,237
    Re: Newbie
    Earlier you said the pool was cloudy green, but the pool is safe for swimming when:
    You can clearly see the bottom of the pool at the deep end;
    The pH is between 7.2 and 7.8, and;
    FC is between the minimum and shock level for your CYA level per the Chlorine/ CYA Chart.
    http://www.troublefreepool.com/content/128-chlorine-cya-chart-slam-shock
    When I make that decision, I consider the error on the CYA test, and use one level down. So if my shock level is 24 ppm FC for CYA at 60 ppm, I use 20 ppm FC as the high level for swimming. Using a lower limit is just my own opinion, because I understand the relationship and know it's ok even a bit higher, but I like to be on the safe side for my grandies. At 24 ppm FC and 70 ppm CYA, I noticed a faint smell of chloramines on my skin when I got out. That's residual FC combining with sweat, skin oils, etc. No one else here in our pool smelled it or felt it enough to comment. I'm a bit OCD, so I swim eyes open on my own after any major change or anything I'm concerned about.
    Jun 2016
    Cleveland
    5
    Re: Newbie
    Keeping FC at 24 requires a lot of drops of test unless I let the FC drop before testing. What do you all do about that? If I test often and use 20-50 drops each time with a 10 ml sample, aren't I going to run out of test very quickly?? Taylor only gave me one small bottle of this stuff and the kit wasn't cheap.
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    880
    Re: Newbie
    Unfortunately one of the downsides to the K2006 is that the R0871 is pretty inadequate when you need to SLAM. As you are realizing you will probably run out. Order a refill from tfttestkits.net and consider some extra R0870 powder and R0013 for CYA while your at it.
    In the meantime you csn use a 5ml sample for FC and count each drop as 1.0.
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    needsajet's Avatar
    Jan 2016
    4,237
    Re: Newbie
    Yeh, we don't always get this straight at the beginning, but yes, you can only do about 11 tests at 48 drops from a 0.75 oz bottle.
    As soon as you can - buy this...
    10g R-0870 DPD powder - TFTestkits.net
    and this...
    2 ounce R-0871 FAS-DPD reagent TFTestkits.net
    Hang onto the bottle you have, because this bottle will not fit in your case. You can refill your existing bottle from this refill.
    Consider for same shipment - speed stirrer, large bottle of CYA reagent
    ONLY if you'll run out before you get new so you're stuck right now... (CAVEAT - this is not TFPC, just my own thing)... get some good quality distilled water (pharmacy might be a good source). Use your test cylinder to measure 44 ml of pool water. Pour it in a clean cup. Add 44 ml of distilled water (measured exactly the same, bottom of meniscus, all that). Add it to the cup. Stir it up. Use the new solution for the test, and each drop = 1 PPM FC. Do NOT use this option for OCLT or final CC SLAM ending criteria.
