Thread: Algae on the bottom of AG pool
    Jul 2015
    Eaton Rapids
    41
    Hello,
    I was gone for a couple weeks for work and my wife did her best to upkeep the pool but when I got back it was pretty bad :/
    The first thing I did was SLAM and the water is looking MUCH clearer now BUT I the floor of the pool is covered in dark green algae. I tried to vacuum it up but it only made a dent. It seems to be stuck pretty good!
    I don't currently have a brush but I can buy one from Wal-Mart if needed. I'm wondering if there is a chemical or something I can put in to help eat up that algae?
    Any help is appreciated!
    7600 gallons AG. Hayward Sand filter. Taylor k-2006.
    Jun 2014
    15,031
    Re: Algae on the bottom of AG pool
    You need regular bleach and follow the SLAM instructions to the letter (link below). Let us know if you have any questions. Have a great weekend.
    dsmith99's Avatar
    Jun 2016
    SW, Iowa
    222
    Don't have a brush??
    A brush is a required tool for proper pool care!
    I brush my walls at least every couple days and hit the floor 1-2 times a week. You must brush the surface to tear up and expose fresh algae, that allows the chlorine to attack and kill it. To do a real good job you probably need to just get right in there and brush, then vac up the stuff you get loose. Probably won't be a one time process to get rid of this. I would keep the FC level on the upper end, does not sound like you are truly done with your SLAM.
    AGP 24' x 54" approx 14000 gal Full sun all day, Hayward 1.5 HP and EC50 D.E. filter
    Stenner 45MPHP10 10 gal/day fixed rate with intermatic ET1125C timer
    Dolphin E10 robotic cleaner, 330 gallon Tiger River Spa, Taylor K-2006C test kit
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    You have a good test kit, no it's time to read the directions on SLAMing your pool in the How To section of Pool School and follow that procedure completely to the end.
    • CC is 0.5 or lower;
    • You pass an OCLT (ie overnight FC loss test shows a loss of 1.0 ppm or less);
    • The water is clear.
    When all three are true, you are done SLAMing and can allow the FC to drift down to normal levels.
    Support the site
