Thread: Thinking about LED lights
    coog61's Avatar
    Nov 2009
    Richmond, TX
    84
    I'm using a Easy Touch 8 control panel (8 yrs old) with the standard 500W white lights (which have failed). Generally what is involved in upgrading to LEDs? Other than the bulbs, any new equipment? Should I stay with Pentair?
    Thanks
    17,500 Gallon, SWG 33' x 21' freeform w/ Sunstone Cobalt Plaster. Attached 6 X 6 Spa raised 12" w/ 6 Jets with Moss Rock Spillover. 25' Moss Rock Waterfall. Pentair Intelliflo VS-3050 for Pool, 2 HP Whisperflo for Waterfall, Pentair Clean & Clear Cartridge 320, Pentair 400K BTU Max-E-Therm heater, Pentair Intellichor, Pentair EasyTouch 4P, Pentair Legend Platinum Cleaner w/ 3/4 hp pump, autofill system, nat gas fire pit. BBB convert
    http://www.troublefreepool.com/new-tx-pool-t17907.html
    38,281
    Re: Thinking about LED lights
    Pentair is not going just have a replacement bulb I do not think ... their LED lights are a sealed enclosure that would require pulling out the old fixture and pulling the wires.
    By far the simplest thing to do is buy a LED bulb (and new seal) and put it in your existing fixture. If you go with one of the color bulbs, you can change the color and modes by cycling the power.
    I have the Colorsplash 3G.
    Aug 2015
    San Antonio
    74
    I was looking at the Colorsplash but found one on Amazon for $60 that has worked great for this season so far. There is no remote but the LED colors are amazing and can be cycled to different light shows or solid colors by flipping the switch.
    Just screw it in. I also changed the housing gasket.
    Matt in San Antonio
    10,000 gallon IG plaster
    Pentair Intelliflow 2VS 3hp 3/4 hp booster pump
    Hayward C-1100 Cartridge Filter
    Sunluway 18w Color changing led light
