Thread: Lowering temperature/ Aeration
    Jul 2016
    Dallas/Fort Worth Texas
    2
    Hello,
    Day three of pool ownership! This is more involved than I imagined! Doing ok with chemicals. My issue is our water has gone from about 78 to 85 degrees in three days. What can I expect in DFW area? I would like to get it back to around 80 if possible. Is aeration the answer? We have 2 sheer descents. Should I try running them at night or try to attach an aerator? How do you attach an aerator? I'm concerned about the energy use to run the descents all night.
    27,400 IG pebble, 60 sq ft DE, 2HP variable pump, 2 sheer descents on 1HP booster pump, Polaris 280 Cleaner, well and softened well water, built 6/16
    38,275
    Re: Lowering temperature/ Aeration
    Welcome to TFP!!
    Sure you could run the descents at night or try to hook up an aerator. Remember it will drive the pH up too.
    It really should not require much involvement.
    What are you testing your water with?
    How are you chlorinating?
    Jan 2012
    'burbs of Augusta, Georgia
    7,336
    If your pool is more shallow, such as a sports pool, folks say they get swampy warm feeling in the hottest part of summer. Running a fountain overnight can help a lot.
    Skippy made one for us and it lowered the temp 5 degrees in a day. Take a look at Skippy's fountain- link in siggy line.
    Jul 2016
    2
    Thank you!
