Thread: Spa on/off timer
    Jul 2016
    Davenport FL
    4
    Spa on/off timer
    Hi, Can anyone advise me of the cost of installing a ON/OFF timer to switch on the spa. The only way to work the spa is by turning the valve on outside the pool screen.
    I have been quoted prices of $1200+ would this be about right?
    Thanks for any help.
    Paul.
    38,284
    Re: Spa on/off timer
    Welcome to TFP!!!
    Need a lot more info. Is this a stand alone spa? Is this a pool/spa combo? What kind of equipment? Etc ...
    Please add your pool details to your signature as described HERE as it will help us help you.
    Jul 2016
    Davenport FL
    4
    Thanks Jason for your reply, I have added some info to my signature, I have just bought this home so I am a little bit green at the moment.
    Aquacal Pool Pump Variable Speed. Hayward Star Clear Plus Filter
    2,000 Gallon In Ground Plaster Built in 2005
    Spa/Pool Combo Cannot Post Test Results.
    38,284
    So, some pictures of the plumbing and electrical might help.
    If it is just a spa, I am not sure why you would need to turn a valve to turn it on.
    You might run into a space issue being a basic member trying to post pictures. If so, To post more/larger pictures, you either need to raise your storage allotment by Becoming a TFP Supporter or follow the How To Post Pictures tutorial.
