Results 1 to 14 of 14
Thread: Help! How to adapt intex strainer intake to use vacuum hose
    Jun 2016
    MUSKOGEE, Ok
    274
    My husband and i have been racking our brains trying to figure out how to adapt to use 1 1/4 vacuum hose. I tried ordering the intex deluxe kit but its now on back order and i really dont want to spent $40 on a junky hose.
    16x48 intex ultra with intex sand filter 2800
    16x48 AG Intel 5600 Gal. Intex sand filter 2800 gph
    Muskogee, OK
    Aug 2013
    south east Arizona
    199
    Re: Help! How to adapt intex strainer intake to use vacuum hose
    start with this Adaptor For 58959 - Intex - probably can get it on Amazon too
    I have a 1 1/4 vacuum hose that has a swivel at one end and that is the end I can wedge into this part. otherwise you might need to play around with some other adapters. (like the end of a filter hose or some gorilla tape or whatever...we call it "ranch rigging" around here LOL) I am pretty sure an 1 1/2 vacuum hose will fit on the outside.
    if the pool has a lot of trash like leaves on the bottom you will have to remove that blue part fairly often and scrape/catch the stuff off the intex screen. it is a pain and one more reason so many modify and add a through-the-wall skimmer to these pools.
    another option is to get the intex clamp-on skimmer Amazon.com : Intex Deluxe Wall Mount Surface Skimmer : Swimming Pool Maintenance Kits : Patio, Lawn Garden (it will come with that blue part) and also find the vacuum plate for it. I never tried the vaccum plate but read some say it doesn't work very good.
    finally, there is the intex robot if your pump is big enough Amazon.com : Intex Above Ground Swimming Pool Automatic Vacuum Cleaner 28001E : Patio, Lawn Garden though you might want to keep an eye on that, prices were half that a few months ago and likely will drop after summer demand is over. sheesh! I paid 55 or 60!
    finally (version 2) if your hose is long enough and you have a ton of junk to get out you can rig it up to siphon over the side with some string, that keeps it out of your filter but will use a bit of water.
    somewhere around 6,800 gal 18 x 4 foot round Intex Ultra Frame AG, finished filling August 29, 2013. toy pump w/ "A" cartridge up and running next day --- July 2015 upgraded to Krystal Clear 3000 GPH pump and 16" sand filter --- May 2016 Intex auto cleaner and in July salt system and Hayward skimmer
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I will see if I can find the part I ordered last year. It allowed me to hook the vacuum directly to the pump.
    Found it!
    Adaptor A With Collar (To Adapt Small Hose [1-1/4 Or 32mm] To Plunger Valve ) - Intex
    RonsPlc's Avatar
    May 2015
    Gaylesville, AL
    458
    I have the deluxe over the wall skimmer (the larger one), and I ordered a vacuum plate. We have been impressed with the ease to hook it up, and the fact that it goes through the skimmer means that the skimmer catches the larger material, making it a whole lot easier on the pump skimmer.
    But we have a pump, and filter that was made for a permanent AG pool, not an INTEX one.
    14600 gal Intex 24' Round 52" deep AG Pool (Heavily Modified)
    200lb sand filter w/2 speed 1.5/0.5hp pump
    Stenner 45MHP10 Liquid Chlorine (well... bleach) Injector. Borates added.
    K-2006 test kit w/Speedstir
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jun 2016
    MUSKOGEE, Ok
    274
    Thank you. I've checked into all these possibilities prior to posting. I'm needing to vacuum now and cannot wait for online. So here is what we came up with in mean time. I have to remove strainer intake and insert this instead. Im having an issue getting all the air out of my vacuum hose no matter what i try though
    Muskogee, OK
    Jun 2016
    MUSKOGEE, Ok
    274
    I'm getting suction to vacuum but the strainer basket is only half full of water and i feel its getting too much air. We did not glue any of the pieces. Maybe that's the problem. Also the 3/4 in pipes is slightly small...any ideas?
    Muskogee, OK
    Jun 2016
    MUSKOGEE, Ok
    274
    Quote Originally Posted by Poolnewbie82 View Post
    I really feel is the hose though because with just the fitting in i get plenty of suction no air.
    Muskogee, OK
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Mine tends to do that sometimes, even with me putting the vacuum hose up to the return, amd carrying it to the inlet that I hook it to under water. (I took the end off of my over the side skimmer and duct taped it to the vacuum hose because it was too difficult to hook directly to the pump.) for me, it seems to be partly because of the second inlet, even though I put the plug in it. I'm still trying to work on a viable alternative. Thinking of closing the plunger valve, then plugging the second hole, hooking up the vacuum hose, reopening the valve and turning on the pump.
    I still vacuum with the air in the basket as long as it isn't too low. I'm looking at a shoo a vacuum, a I don't like how the screen on the inlet (with the outer cover off) clogs up with any little amount of debris.
    Since I only have the 12x30 pool, an in wall skimmer is not viable for me. I do have the over the wall skimmer, which comes with the blue plate. What I made work was go get a pool hose connector from Ace, like this: Ace Pool Hose Connector 9 in L x 1 1 4 in W | eBay Disconnect the clear hose from the skimmer, use the adapter to connect the hose (still connected to the blue plate) to the vacuum hose, and I had to cut part of the adapter off because it wouldn't fit into the blue adapter all the way due to the inlet (using the large 1.5 inch inlet and return pieces. (next year, going to get someone to cut the face off of that inlet because it catches too much stuff.
    Before I got my over the wall skimmer, I would disconnect the inlet hose from the value, place it over the wall, and use the adapter to connect to the vacuum hose.
    I'm still thinking to go to Lowes with that blue adapter and see if I can find something to fit right over it. The two vacuum hoses I have, the white end piece would not fit over the blue adapter. (I have the older pool with only 1 inlet and 1 return Im using this year). Last year I used the newer pool (2 inlets)and it was easy to remove the inlet cover and shove that white adapter right into the hole.
    Jun 2016
    MUSKOGEE, Ok
    274
    Quote Originally Posted by PAGirl View Post
    I was wondering about 2nd intake as well. I havent tried to plug. Do you have a have filter?
    Muskogee, OK
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I think I have the same filter as you.
    Jun 2016
    MUSKOGEE, Ok
    274
    We dont have anywhere close to get a skimmer so we made due. Won't be fooling with it today...storming here
    Muskogee, OK
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I'd love to get a skimmer, but two things are stopping me. Losing an inch or two of water height, and the husband doesn't want me to cut the liner. I have and extra, larger plunger valve that came with the new filter when I had my 18' with the larger inlet, but I'm pretty sure I'd have to make the opening larger. It would make vacuuming better as there should be more flow. I would plug the other, smaller inlet. One of these days I will take a good look to see if it's possible.
    RonsPlc's Avatar
    May 2015
    Gaylesville, AL
    458
    That is the reason I stayed with an over the wall skimmer (I can maintain a higher water level in the pool).
    I made a plug for my inlet/outlet ports using a piece of the foam board you get at Lowes (the thick stuff 2") ... I cut a square that was a bit bigger than what I would need, and took off the strainer from inside the pool. I then pressed the foam piece against the fitting to give me a mark to follow. I used a SHARP knife to cut the foam on a little of an outward angle following the mark left from the pool fitting. I still need to put a bolt with a wide washer on each side through the middle to ease the removal of the plug when it is inserted in the port.
    I will take some pictures of what I am talking about, and post them for you later today.
