Thread: EcoTech VS energy usage
    May 2008
    Long Island, NY
    151
    A couple of years ago I replaced my failing Super Pump motor with a EcoTech VS motor. I recently installed a energy meter on my pool/pond circuit. The meter is integrated with my Smartthings hub and the charts are done using Initial State.
    Pond running (24 hr/day) - 210W
    Pump running 100% - 1200W (990W pump only) approx 45 gpm
    Pump running 50% - 340W (130W pump only approx 20 gpm
    SWG 195 W
    GPM readings are from a flow-viz flowmeter.
    I didn't realize how much energy the pump saves.
    The top chart is my pond and pool energy usage over 24 hrs. The pump runs at 100% for two mins then drops to 50%. The SWG powers up with the pump via a relay and current switch.
    On a other note, my kids left the cover open on our hot tub last night, look at the spike in energy usage on the bottom chart.
    Pool Details: 25,440 Gal IG Vinyl 21x40 Mountain Pond (Graphex)
    Filter: Hayward Micro-Clear DE (48 Sq Ft)
    Pump: Hayward SP2603VSP VS Super Pump
    SWG: Circupool Si45
    Cleaner: Pentair Kreepy Krauly Prowler 820
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: EcoTech VS energy usage
    that is great, I have one but have not got it working yet, I need more Zwave devices to connect my pump, seems it is too far..
    May 2008
    Long Island, NY
    151
    I have a Aeon Labs home energy monitor on the breaker (in my main panel) that feeds my pool panel. My pool panel powers my pond and pool (pump, SWG, light and a outlet that I use for outdoor string lights). I have a z-wave relays that I want to wire into the outlet and pool light switch. I hope it is close enough to get a signal.
    SWG: Circupool Si45
