Thread: Chlorine good but ALGAE?!?!
    Help straighten me out on something. We have a SWG that is working fine. Chlorine level is at 6.5 right now. PH at 7.6. CYA at 70-80. Everything seemed fine. There was a tinge of cloudiness a few days ago but I ran pump overnight and felt good about how clear it was. But, it wasn't crystal clear. Now, with all levels in check, we feel like algae is setting in. Chlorine level has been good for several days. We never let it get to nothing. My question; is it possible that a tinge of algae was hanging out and, even though chlorine levels are fine, it is able to start growing and producing an all out algae bloom? Obviously, we bring out levels up to shock levels when we want to kill algae. This may be my answer. Normal chlorine levels can maintain pool water but it takes SLAM level chlorine to get rid of algae. ??? I appreciate the help.
    29K Gallon, Concrete bottom/Fiberglass sides, SWG, Sand Filter, 1HP Pump, Gas Heater
    Kansas City, KS
    Jan 2012
    'burbs of Augusta, Georgia
    7,357
    Re: Chlorine good but ALGAE?!?!
    Please give us the most current test results (and how are you testing? Which kit do you use?)
    FC
    CC
    pH
    TA
    CH
    CYA
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Quote Originally Posted by jonnyrr77 View Post
    I would suspect that with an SWG you may have let the chlorine drop below your target inadvertently that would allow algae to start (it happens to me when things heat up).
    Yes, SLAM level to kill it or really, the algae causes your chlorine to be consumed faster......thereby falling more. SLAM level is calculated so that your chlorine is killing algae faster than it reproduces.
    As yippee asked, how are you testing? A good test kit is a must have. And if that is what you have, maybe you could do an overnight free chlorine loss test to confirm algae or something in there consuming your chlorine.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
