Results 1 to 8 of 8
Thread: Help me just heat my overflow spa.
    Jan 2016
    Long island NY
    80
    Trying to figure out to just heat spa with out overflow flowing into pool. Here's some pics
    Starting from top left
    Water fall/water fall return
    Spa return
    Skim/main drain
    Spa suction.
    Thanks in advance!!!
    20x40 rectangle, 28,500 gallons, Vinyl liner, Hayward cartridge filter VSP, Hayward aqua connect automation, connected spa with overflow, Hayward heater, automatic cover, TF100 kit
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Re: Help me just heat my overflow spa.
    On drain side close everything except the spa drain.
    On return side, close everything except Spa return.
    That will cause 100% circulation of the spa only. Nothing coming from or going into pool.
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    If you only allow return flow to go to the spa and only allow suction to come from the spa, that would do it. So... the handle between the waterfall and the spa returns would be closed to both waterfall returns (handle toward the spa return). Then the 3 way suction valve on the far right would only be open to the spa suction (handle toward the spa suction). Configured this way you would have NO flow to your pool at all.
    Isolated Spa - 345 Gallons
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Turn both of these valves 180 degrees. You want both of them the EXACT opposite of what is pictured here (which is fully closed)
    Suck side:
    Return Side:
    Jan 2016
    Long island NY
    80
    Thanks, you guys are the best!!!
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Did it work? Or did you not get a chance to try it yet? Reason I ask is because the success of our instructions will be based on your pipes being labeled correctly.....
    Jan 2016
    Long island NY
    80
    Yes worked great!!!!!! Thanks again all who replied
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Sweet. Enjoy the holiday weekend.
