Results 1 to 7 of 7
Thread: Am I doing something wrong?
    Jun 2015
    O'Fallon, MO
    45
    Background: Didn't open pool until a couple of weeks ago, then realized my sand tank cap was off so lost water after putting in CYA. Found cap, refilled pool, tested & adjusted. Scooped thousands of tadpoles out & have kept pool at shock level for this entire time, keeping pump on recirculating during the cap snafu. I've really only been filtering since last Sunday, so that's 5 days. Tested CYA Wednesday & got a reading of a little over 20 so circulated some more then per pool math. Here are my numbers & a picture today:
    FC: 10 (adjusted back up before posting per pool math)
    CC: 1
    pH: 7.5
    TA: 130
    CH: 0
    CYA: adjusted to 35 on Thursday, but did have some rain & have backwashed 5 X since then.
    I STILL can't see bottom of pool & I lost my vacuum head in the water . I can see halfway down now & couldn't see that last week so I know I'm making some progress. What should I be expecting? I think I've cleared all the leaves, etc. off the bottom, but I also can't get the vacuum to work-not sure if I have a faulty hose or what but I'm crabby with my daughter & think the pool is probably causing some stress-lol!
    24 x 52 intex AG round with well water-water has no issues with rust or other contaminants
    2800 GPH Intex sand filter pump
    Located in Missouri
    Jun 2014
    15,153
    Re: Am I doing something wrong?
    Definitely stick with the instructions and methods noted on the SLAM page (link below). Can you confirm please what test kit you have?
    Jun 2015
    O'Fallon, MO
    45
    TF100. I'm following instructions-just not sure if still not seeing the bottom would be normal.
    Located in Missouri
    30,421
    The SLAM process clears thousands of pools each season. There is no reason it won't clear yours. It sounds like you have had a lot of starts and stops. The SLAM process works best as one continuous application of chlorine until your pool is crystal clear.
    Review the SLAM article and stay with it.
    Jun 2014
    15,153
    Right... and like Dave said ... consistency and maintain the proper SLAM FC level is key. You might want to confirm your CYA again in the next day or two. If it's 30, SLAM FC is 12. If it's 40 ( or 35 & above), then FC SLAM is 16. Just adjust accordingly. Have a nice weekend.
    Jun 2015
    O'Fallon, MO
    45
    Thanks, guys! I thought it took a week for the CYA to read accurately. Should I dose based on what I set the level on in poolmath? Like for the amount of CYA I should have after it dissolves but before it reads? TIA again!
    Located in Missouri
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Yes, dose chlorine based on what you expect it to be. CYA can be tested 24 hours after it is dissolved from the sock. More here, Pool School - Recommended Pool Chemicals
