Results 1 to 18 of 18
Thread: Main Drain NOT Centered!
    Otis B.'s Avatar
    May 2016
    Abington, PA
    28
    [IMG][/IMG]Hi All,
    Pool guys came this week and started the plumbing. I came home from work and noticed that the main drain is about a foot away from the old drain, which was located in the deepest part of the pool. PB on the phone tried to dance around it and get me to accept it. Judging by the pictures what are your opinions? Am I wrong to insist that they dig it up and move it over a foot?
    Also...PB told me that all the plumbing from the pool to the equipment was being replaced with 2" PVC but the sub doing the plumbing had only 1.5" on his truck. They are coming back tomorrow with the 2". Would 2" be overkill on a 17,000 gallon pool? Or would 1.5" have been good enough? (PB is installing a new 450' Hayward cartridge filter with a Hayward Maxflo VS 1.5 HP.)
    [IMG][/IMG]
    [IMG][/IMG]
    16,000 QuartzScapes Barbados Blue finish, Hayward 450 cluster cartridge, Hayward Max-Flo VS 1.5 HP, Goldline SWG
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Re: Main Drain NOT Centered!
    That wouldn't bother me and I am pretty nuts about things. You are noticing it more now because the small puddle is showing you where the true center is. Once the finish is on the pool and it is filled, I doubt it will catch your eye. Is this a rebuild? What do you mean by "where the old drain was"?
    If they are offering to switch to 2", run with it. Not overkill IMHO.
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    Otis B.'s Avatar
    May 2016
    Abington, PA
    28
    Rebuild, Mikemass.
    I do finish work for a living (flooring installer), so I'm also pretty nuts when it comes to these things.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I would prefer to have it centered myself... MUST HAVE SYMMETRY!
    2" isn't overkill in any pool. Less head loss in your plumbing with larger diameter makes for more efficient flow and pump utilization.
    Isolated Spa - 345 Gallons
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Quote Originally Posted by Otis B. View Post
    Rebuild,
    K. The reason I asked was that on a rebuild I doubt it would make any sense to dig up all old lines buried under the concrete. So they may have moved new drain over a bit as to not have to work around old lines, elbows, pvc etc, from the old drain.
    May 2015
    katy, tx
    31
    Even after it was filled, it would bother me just knowing it isn't centered. Even if I was the only one who noticed.
    16,500 gallon in-ground pool and spa with Quartzscapes Midnight-blue and pretty sparkles
    Aqualink RS with PDA
    Jandy Pro Series Plus HP 2 HP 2 Speed Pump
    Jandy CV460 Cartridge Filter
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,410
    Take a read of this:
    http://www.doh.wa.gov/portals/1/Docu...bs/333-119.pdf
    I don't think yours is to code. I THINK there should be TWO of them or one long one to help prevent entrapment from suction.
    Check into this THEN work on the centering of the one IF that is allowed.
    Kim
    Feb 2014
    Central Minnesota
    5,080
    Great point, kimkats. I believe with any new or remodeled pools, you must have a pair of linked main drains. Plus, it's a good idea.
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    I don't think I have seen ANY pool built w/in the last 10 ish years in my area that doesn't have a "Split" main Drain.
    Feb 2015
    Davis, CA
    97
    When I had my pool built, I insisted on 2.5" or 3" plumbing from the pool to the equipment pad because they are far apart. If he promised you 2", you should insist on 2" drain not 1.5. 2" drain has about a 43% more capacity than a 1.5" drain.
    As other have mentioned, the main drain should be dual drain and symmetrical. It would drive me nuts. I don't care if the "old" drain was in the way. They are paid a lot of money to do it correctly.
    Pool Remodeled June 2015. 18K Gallon IG kidney shaped. Pebble Tec (Tahoe Blue) finish. Jandy ePump 2HP. Hayward SwimClear C2025 filter. Hayward SWG. Jandy iAqualink RS6 automation. 6 Deck Jets. Pool Remodel Link Future: Acid automation. Chlorine automation for winter. Solar panels.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,798
    Yes, clearly not code-compliant. Since it has to be changed anyway, I'l get a rectangular one instead of the round ones. They look better and don't have the lip that the round ones all have. That means you can scoot debris into it easier vs it just catching on the lip.
    Bonus - I just found the best main drain out there (IMO). It is rectangular as mentioned above, but it also allows you to have a pebble/plaster finish on the main cover to make it very unobtrusive. They also have options for vinyl liners as well.
    http://www.poolfittings.com/channel-pebble-top/
    Same concept as the Pour-a-lid skimmer covers which we have.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Jul 2012
    Tallahassee, FL
    30,410
    I LOVE those ^^^^^^^^^^^^^ OH SO PRETTY! Of course there is no price but........
    That is the shape I was looking for but could not find a link to any so gave up.....
    Kim
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,798
    Yeah, probably not cheap, but I'm pretty open-minded regarding pricing on things that have a big visual impact (or are high quality). I'd go 2 or 3 Franklin's for something that nice looking regardless of what it really should cost being plastic. They had to design it well which has a cost. And its made in the USA!
    IrwinK's Avatar
    Apr 2016
    Orlando, FL
    338
    I had to use 4 drains because of the separate feature pump. They were to be in a row evenly spaced apart but as usual with much of the PB's work did not come out as planned. Made him fix it and reluctantly he did.
    Re: the pebble/plaster finish on main drain covers mentioned:
    My PB promised and put in writing to do this and I thought I would be getting those special covers.
    Now it seems all he meant to do was have the plasterers put the pebble/plaster in the center of the ordinary drain covers as I saw on another pool he built.
    Covers are sitting there waiting for the plasterer and the plaster will block the holes in the center. They aren't even the large drain covers I see available.
    I have 2.5" and 3" plumbing going to these drains with small covers and the centers will be blocked.
    Hope I don't have problems with this.
    Anyone have their drain covers finished with plaster/pebble?
    My 2016 Build 14'x19'x35' IG Gunite 15K Gal. Roman, 4'-5' deep, 6 returns, 3 sheers
    4 deck jets, 2 Pentair XF22005 Pumps, Clean&Clear 200 Cartridge Filter, Brick Coping
    2 Pentair 5g 12v LED Pool Lights, 1 Pentair 12v Globrite LED in step area, 2 Bubblers
    Inline Chlorinator - SWG later, WetEdge Mediterranean Pebble, Intermatic MultiWave
    43'x33' Screened Paver Deck&15'x30' Lanai, Doheny Discovery (S200) Robot, TF-100
    Aug 2014
    Houston tx
    2,524
    Bmore, I love those drains! What a great idea! Now why didn't you tell me about this for my pool???
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,798
    Quote Originally Posted by Marlahoutex View Post
    You and me both!
    Otis B.'s Avatar
    May 2016
    Abington, PA
    28
    2 of the workers are here now with the 2" PVC. Boss is supposed to show up soon to discuss main drain issue...
    Next question - Should the 2" PVC for the returns come thru the wall or be reduced to 1.5" to create pressure? Or will the eyeballs that get attached create pressure?
    Feb 2016
    Atlanta, GA
    145
    Let the eyeballs create the pressure (you can swap them out to different sizes later)
    Always go with the biggest pipe
