Thread: Attached raised Spa leaking down
    Mar 2016
    Santa Clarita,CA
    14
    Hello, My question is in regards to my Jandy 7305 check valve. the spa leaked down about 2 feet the other night so I replaced the flapper with a new one and the next morning the Spa leaked down about 4 inches, Is it possible that the whole valve housing needs to be replaced as that the flapper isn't seating properly due to wear? the pool equipment is 16 years old.
    Thanks for any help
    Dave
    16x36 free form gunite, 8' deep end, raised spa attached, 18,000 Gallons, Stone Scape mini pebble, remodeled 8/10/2015, Pentair variable speed pump #011018, DE filter, Pentair Easy Touch upgrade automation w/ screen logic, Pentair 520549 Easy Touch indoor control panel, is4 spa side remote, Pentair Mini Max plus 400 heater, Hayward Navigator pool vac, IntelliBrite 5G color LED light in pool and spa
    38,290
    Re: Attached raised Spa leaking down
    It is possible, but I would think unlikely.
    There are a few paths the water could take ... either through the suction side or the return side (and maybe a make-up path for overflow). Depends what your plumbing is like.
    Point is, the check valve might be fine and the leak down could be through a 3-way valve.
