Thread: Newbie question....confused about alkalinity.
    Jun 2016
    Utah
    13
    Hey everyone, new to pool ownership and the forum. First some background on my pool setup:
    Intex above ground vinyl pool 12x24x52
    Intex SWG
    Set it up about a week ago. After filling it up, I shocked the water at the advice of the local pool shop, filled it with the proper amount of salt and ran the filter for 24 hours to get it all dissolved. Added the amount of CYA indicated in Intex's instruction manual based on my pool size a few days ago. Last night after my filter and SWG had been running for a few hours I tested my water. Not sure if that was a good time to do it or not.
    I purchased a Taylor Test Kit 2500. My levels were as follows:
    FC - 5
    PH - ~7.4 (Still not sure what color of pink I should be looking for)
    TA - 220
    CH - Forgot to perform this test last night (it was late).
    CYA - 50
    Now I know PH is minutely low and CYA is low for a SWG pool. TA is obviously high and FC is good. The question is, should I worry about adding anything or trying to lower Alkalinity? I get the impression you only really need to worry about TA if it's causing a problem, but doesn't high TA reduce the effectiveness of the FC? Also, I know my CYA is low for a SWG pool, but I only added the stuff through a sock (it all dissolved out of the sock) a few days ago, should I wait and see if it goes up in a couple more days?
    I'm having a "pool party" on the 4th and want to make sure I'm not going to have issues. The water looks clean and clear, although I have had a few Boatmen in the pool so perhaps I have some algae started that I can't see? This is all new to me so I'm learning as I go. Thanks everyone for any advice you may be able to give!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Newbie question....confused about alkalinity.
    Welcome to TFP!
    Alkalinity is one of the last numbers to concern yourself with once you have your other chemistry in line. TA is a measure of your water's ability to withstand changes in pH. The higher the TA, the harder it is to change the pH, intentionally or environmentally. With a higher TA, you'll usually experience a faster pH rise over all because high TA (carbonate ions, mostly) in the water makes carbon dioxide outgas faster (during any type of aeration). CO2 outgassing drives pH up. Lower TA = lower pH rise. TA level has no effect on chlorine's ability to sanitize.
    If you're chlorinating with trichlor or dichlor, they are acidic. They will combat this pH rise but will insidiously add CYA to your pool over time if used regularly. The easiest advice is to just maintain your pH between 7.4 and 7.8 and each time you add acid, that brings down your TA.
    Here is a guide to lowering TA more intentionally if you're experiencing fast pH rise and want to attack it, but usually not necessary. Pool School - Lower Total Alkalinity It's a process that takes several days to weeks, depending on how high the TA is and if additional aeration is used.
    Isolated Spa - 345 Gallons
    Jun 2016
    Utah
    13
    Great, thanks for the information. I was thinking that would be the best course of action at this point, (simply monitoring pH and adjusting it down when needed).
    This site is great and I've gotten a lot of very useful information from it. I'm kinda going through information overload.
    Thanks again for the reply.
    Intex 24x12x52 AGP (8400 Gallons), Intex CS8110 SWG, Intex SF80110 Pump w/ Sand Filter
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by Dragoth View Post
    Sent from my SM-G935T using Tapatalk
    Glad you're enjoying the site. I understand completely about the information overload. I've been on the site for about 2.5 years and I still learn something new all the time!
    Chasmengr's Avatar
    May 2016
    Omaha, NE
    156
    Good thread. I needed that TA-pH info, too. Thanks
    Chas & Cheryl (first-time, third-year pool owners)
    Radiant Metric Oval AGP 16'x32'x52"; Pentair: Clean&Clear 150 Cartridge, OptiFlo 1.5 Hp 2-spd, and 320C Feeder (all mounted below water level); Taylor K-2006 & SpeedStir; Maytronics Dolphin E10 (aka Einstein)
    installation pics (2015-2016)
