Results 1 to 10 of 10
Thread: How long after adding liquid chlorine ( maintenance mode) should you wait b4 swimming
    Jun 2016
    Marlboro, NJ
    176
    Hi all,
    Assuming a balanced and clear pool and you are adding liquid chlorine just to keep your levels up (meaning you haven't fallen below min thresholds and aren't attempting to shock the pool with the dosaging) - how long should you wait after adding liquid chlorine before going in the pool?
    Assume scenario:
    FC: 6
    CC: ~0
    CYA: 60
    Ideal Target FC = 7
    Min Target FC = 5
    So say you add enough liquid chlorine, per pool math, to bring you just around 7.5 to 8.0 FC. How long should you wait before going in the pool, assuming pump is running to circulate? Is there a set time or is 10-30 minutes sufficient to let it distribute and because your anticipated FC level is within normal use range, you don't have to wait that long?
    Pool Type: In Ground, Liner. Shape: Free form/kidney
    Filter/Pump: Brand new (2016) DE Hayward 4820 / Brand new (2016) Pentair VST 2
    Heater: Yes (older)
    Location: NJ. No tree/leaves overhead. Limited shrubs near/over waterfall feature
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Re: How long after adding liquid chlorine ( maintenance mode) should you wait b4 swim
    I would pour it in, work up a sweat brushing it around and jump right in to cool off.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Jun 2016
    Marlboro, NJ
    176
    what if i am lazy and fearful of tearing my liner more with my brush and thus i did not brush anything around and simply allowed the pump to do that?
    Heater: Yes (older)
    30,426
    Brushing is an absolute essential part of good pool management. You don't have to do it daily but you have to do it.
    If you are fearful of tearing your liner you might need a new brush.
    Jun 2016
    Marlboro, NJ
    176
    Yes, I am working on the new brush part. There are certain corners of my pool and thus the liner that are prone to being ripped (i now have a giant ugly patch in two spots as a result) and i am waiting to purchase the perfect 360 brush that will be less likely to cause it, but many of the reviews of these brushes state they break...so still holding out
    Heater: Yes (older)
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Quote Originally Posted by ionizer View Post
    LOL. Even more of a reason to jump right! Srs though, an 8.0 FC isn't hurting anyone. For generations people have been made to believe high chlorine is the enemy.... Causes dry skin, red eyes, itchy skin. None of that way of thinking is true. It's your friend. Pour it in, jump on in, and splash around. That'll mix her up.
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    Jun 2016
    Marlboro, NJ
    176
    Quote Originally Posted by mikemass View Post
    i just wasn't sure how long it took to spread around and whether there was a semi-standard "wait 30 minutes"
    its less about me and more about ensuring the 2yo's safety...ya know delicate skin and what not
    Heater: Yes (older)
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    If you add very slowly in front of a running return and brush the bottom of the pool in the vicinity of where you added, you could jump right in after brushing without a concern.
    Isolated Spa - 345 Gallons
    Jun 2016
    Marlboro, NJ
    176
    well at this point it's been 2 hrs, so i think its safe even if i havent brushed
    Heater: Yes (older)
    Jun 2015
    Fort Pierce, FL
    129
    yeah 2 hours is definitely plenty of time... If my pool is nice and clear and I am ready to jump in I will dose with chlorine after I get out. It's also good practice to test, dose, and then put on sunscreen and wait at least 15 minutes for that to dry on to your skin before jumping in
    Intex 16x48" Ultra Frame AG Swimming Pool 5K gal
    intex 2650 sand filter
