Thread: Need some assistance.
    Dejavu21's Avatar
    Jun 2016
    Spring, Texas
    25
    Went to pool store to have my water tested and the results are different than mine.
    Test Store My Test Kit
    FC 2 <.5
    TC 2 <.5
    PH 7.2 6.8
    TA 90 50
    CYA 80
    The only thing done between their test and mine was I added Pool Perfect Weekly (Their suggestion) about 30 minutes before I used the test kit.
    Question:
    1) Did the Pool Perfect bring the readings down?
    2) Should I trust my readings over the store readings?
    Pool Details - 20,000 Gallon Chlorine, IG, Dark Pebble Finish, Cartridge Filters
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Need some assistance.
    What test kit are you using?
    If it's a recommended test kit, trust your results over the pool store any and every day of the week. I would get your pH up as soon as you can and get more FC in your pool. Have you tested your CYA with your kit?
    FYI... pho$phate removers are not necessary at all in a pool that's properly sanitized with chlorine.
    Isolated Spa - 345 Gallons
    Dejavu21's Avatar
    Jun 2016
    Spring, Texas
    25
    I have a basic kit that does not test for CYA. I need to invest in a good kit. Any recommendations?
    Feb 2014
    Central Minnesota
    5,080
    Check out this link to recommended test kits: Pool School - Test Kits Compared
    The best test kit you can buy in terms of the tests you need AND value is the TF-100 from TFTestkits.net (see the link in my signature). The K-2006 from Taylor is a good second choice, just not as many of the reagents that are needed.
    Dejavu21's Avatar
    Jun 2016
    Spring, Texas
    25
    Thanks
    Aug 2015
    Orlando
    116
    If you follow along here, there are a couple good ones, as folks here will tell you, a good test kit is not an expense, but an investment. The TF100 or Taylor K2006 are both great pieces, important to use FAS-DPD chlorine test, for better accuracy
    http://tftestkits.net/TF-100-Test-Kit-p4.html
    JV beat me to it!
    Phil
    ~9600 gal gunite pool, NEW July 2015; Pentair Intelliflo 2 VST pump; Pentair C&C 150 filter; Pentair Intelliclor IC40 swg; solar heat w/ Pentair Solartouch controller, screened. Taylor K 2005 test kit, FAS-DPD separate test, Taylor K1766 salt test
