Results 1 to 8 of 8
Thread: turning timer off to run pump 24/7
    May 2016
    HUntington, NY
    13
    New pool and my service set up intermatic timer. I'm about to add some stabilizer to increase my CYA and want to make sure the timer doesn't shut the pump down while it's dissolving. Is this as simple as removing the "Off" dog from the clock?
    thanks!
    Mike
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Re: turning timer off to run pump 24/7
    Yep
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    May 2016
    HUntington, NY
    13
    thanks!
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Haven't used an Intermatic in years, but I am pretty confident removing just the "Off" tab will do the trick. But removing both definitely will.
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    I can vouch that leaving the green "on" tab in mine will keep it running 27/7. I Just take the red one out.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Did you need those 3 extra hours for swim meets?
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Omg. Lol. Hum. I guess so. Seems like they last that long.
    triptyx's Avatar
    Apr 2016
    1,438
    hehe, it's ok to leave the "On" tab on the dial. The little tabs that engage/disengage the on/off lever are at different spots on the arm, so the on tab won't interfere with the switch when it's already in the On position.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
