Results 1 to 9 of 9
Thread: Bubbles in pool
    Tmkowalski's Avatar
    Feb 2015
    San Antonio Texas
    34
    Bubbles in pool
    I have checked off the 3 things, water level, skimmer seal and return coupler. All are sealed and water level is fine. I also show no aeration at all at skimmer lid. None whatsoever. I still have a steady flow of minute bubbles coming out of returns. I read something about seal for impeller. Any thoughts?
    18,000 gal. Inground plaster. Pentair FNS Plus DE 48sq ft. 1 1/2 hp pump. Pentair Mini Max NT spa/pool heater. Automated w Goldline control pad inside and Aqua logic main control panel outside . Test strips and weekly pool store water testing. Attached spa w waterfall. Polaris 280 sweeper. Pool over 10yrs old.
    Apr 2016
    Rockville MD
    43
    Re: Bubbles in pool
    Check the drain plugs on the suction side of the pump as well as the pump lid seal.
    20x35 in-ground oval. Wet Edge Luna Quartz finish. Hayes Super Pump with AO Smith V-Green 165 VS motor. Polaris 380. Enersol solar heating with automatic controller. Automated chlorination with Stenner pump.
    Tmkowalski's Avatar
    Feb 2015
    San Antonio Texas
    34
    Re: Bubbles in pool
    Both are sealed. What I don't get is there isn't any air bubbles at all in pump lid, yet I still have aeration from returns.
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Re: Bubbles in pool
    Do you have a SWG? I understand they produce bubbles.....
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Bubbles in pool
    Yes, my SWG blows bubbles out of the return closest to the pump. If no SWG then there may be a suction leak to track down. More on that here, Pool School - Suction Side Air Leaks
    Tmkowalski's Avatar
    Feb 2015
    San Antonio Texas
    34
    Re: Bubbles in pool
    No I have a DE system.
    Feb 2016
    Spring/TX
    57
    Re: Bubbles in pool
    If you have a 3 way valve in front of your pump you could have bad orings in the valve causeing an air leak. Move the handle does it get worse or better, if so then the shafts orings need to be replaced.
    But always make sure your lid orings is alright without any leaves or grass or anything stopping the contact between the gasket and the lip of the pump on it and make sure you lid isn't cracked.
    If you take a picture I should be able to help more.
    Tmkowalski's Avatar
    Feb 2015
    San Antonio Texas
    34
    Re: Bubbles in pool
    What puzzles me is I show no bubbles thru pump cover at all. Trying to send pix, a little confusing.
    Tmkowalski's Avatar
    Feb 2015
    San Antonio Texas
    34
    Re: Bubbles in pool
