Results 1 to 8 of 8
Thread: Advice with Pavers?
    Jun 2016
    marion/ohio
    19
    Advice with Pavers?
    Since my last thread, I have drained my pool due to it being 3 inches or greater unlevel. we are now leveling ground, then will apply sand, liner, gorilla pad.
    My question is .... is that the correct order to lay "flooring", only laying sand where the actual pool liner will set.
    And.... i have 2x4 blocks to go under each leg. My question for that is... dig the "paver"/ wood, so that it lays flush with ground? correct?
    do i tamp the little square that i dig for it? if they need moved back as pool fills, do i just dig enough to slide it back? then use paver sand to fill where i pulled it back from? before i set the block into my square should i add a little paver sand and tamp it then add the block?
    any advice would be appreciated as i want this as level as possible.
    also to ensure levelness of the blocks, do i check level from block to block all the way around pool site?
    however i plan to add the blocks after the pool is in place, under each leg..... ??
    also, sorry, do i pull legs out as it fills, or let them adjust themselves, as i adjust the wood blocks under them?
    This is the most tedious part to me, and I want it perfect, or close to it
    New to Everything Here!
    18x52 intex ag pool / 2100 gph sand filter pump / vinyl / 6981 gallons / Taylor K-2006
    Pool cover /Intex Wall Mount Skimmer 58949e
    Jun 2016
    bc
    152
    Re: Advice with Pavers?
    trying to use a level from block to block is not the most accurate way to do it. While it will work if your out 1/8th on one block by the time you get around the pool it could be out a 1" or 2". Best way is to go rent a lazer level with the stick and beeper.
    Jun 2016
    marion/ohio
    19
    Quote Originally Posted by Zrock View Post
    any advice that does not involve renting anything? lol , i am all rented out. this pool has turned into a money pit.
    my funds have no more room for renting anymore equipment.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,832
    Look up using a water level. It is a simple DIY device that can get you very level and costs only a few dollars in parts. There have been a few threads about using them here.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Jun 2016
    Celina, TX
    34
    Quote Originally Posted by cbooth8674 View Post
    I made a water level to do ours out of 3/8" clear tubing and a couple of 1x3's and yard sticks. Google it. Very simple and easy. Our pool is within 3/8" all the way around.
    I see I was beaten.....
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,832
    A self leveling laser level is the easiest way, I use mine for all kinds of projects, it's an expensive tool to have sitting around tho.
    Chuck-
    Jun 2016
    Florida Keys, Florida
    4
    I used a water level, less than $3 for tubing and an old yardstick, works great!
    Jun 2015
    Waycross, Ga
    36
    water level is what I'm using.
