Thread: Iaqualink dead. Anyone have a service/troubleshooting guide?
    Jun 2016
    Martinez, CA
    207
    Installed a replacement aquapure system and connected up to our existing jandy aqualink RS power panel that I upgraded to the original iaqualink system when they came out in 2012. Aquapure works fine but when i re-energized the power to the panel, there seems to be no power to the controller. Here's what Ive done or found:
    1. Verified breaker to low voltage transformer was good and power ptesent
    2. Checked transformer low voltage power to circuitboard. Circuit was open
    3. Replaced low voltage transformer and plugged lead into circuitboard
    4. Controller still didnt work. Noticed one square ic chip with ~ 8 solder leads is getting hot quickly when power lead is plugged into circuitboard.
    5. Disconnected power to circuitboard until I figure this out.
    antone have a troubleshooting or repair guide for this system/circuitboard?
    18,000 gunite pool/spa combo. Pebble tec, iaqualink rs8, cl580 filter, aquapure 1400, 400k btu lx heater, 10 solar panels, jandy 1hp, 1 1/2hp, and 2hp stealth pumps for circ, spa, waterfall
    Jun 2016
    Martinez, CA
    207
    Re: Iaqualink dead. Anyone have a service/troubleshooting guide?
    Here's a pic of the board showing the square chip that seems way too hot. Its directly above the word "products" printed on the board and is labled U3 on the pcb. The chip looks to be a step down voltage regulator labled lm2676 sadj as i looked it up on the net.
