Results 1 to 16 of 16
Thread: Slightly cloudy, June bug..
    Jun 2016
    Central Oklahoma
    56
    Had a sparkling pool a few days ago.. Found a lot of June bugs in pool and pool was cloudy..
    Pool #'so today..
    FC 2
    Cc 1
    pH 7.2
    TA 160
    Cya 90
    Ch 325
    May/2018 AGP Coleman 24x52 vinyl, 13.6k gallons, Harris H1572228 Vortex 16 inch Above Ground Sand Filter System with 3/4 HP Pump, PoolBlaster Max, TF-100
    Run pump 24/7
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: Slightly cloudy, June bug..
    Unfortunately the June bugs had little to do with it, your FC is entirely to low for your CYA of 90. CYA/FC chart doesn't go to 90 for a SWG pool, but I would have FC at a minimum of 5 or 6 and target 7 or 8 with that CYA.
    Time to SLAM with the CC over 0.5, since its early hopefully it will be quick. Your slam target is 35, sorry.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Jun 2016
    Central Oklahoma
    56
    Ok, thanks much.. So Slam would be add more than 4 gallons 1 qt of bleach 8.25% to pool.. Am I understand that correctly??
    Run pump 24/7
    Pool Tool's Avatar
    May 2014
    757
    Yes, you are spot on. Would you consider a partial drain to reduce CYA to say 70? That is about a 20% (10") replacement. It would help with SLAM (a little) and would help with overall SWG later.
    Jun 2016
    Central Oklahoma
    56
    Sure.. Wouldn't hurt anything.
    Run pump 24/7
    Jun 2016
    Central Oklahoma
    56
    Sure.. I wouldn't mind replacement.. What does clorine level need to be to be safe to swim. Might start slam after holliday..
    Run pump 24/7
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Depending on where Kingfisher is CYA of 80 might be better going forward.
    Please update your location to include your State so it shows up over there <-----.
    Pool Tool's Avatar
    May 2014
    757
    Your elevated CC will actually be much more irritating than high FC. CC is what is responsible for that chlorine smell and red eyes. Like pooldv said, 80 ppm CYA might be apropos if you are in a warm climate with lots of sun. Update your state/area please.
    Otherwise it is safe to swim up to Slam levels, 35 ppm FC at 90 CYA. Raising FC and removing the cover if you have one on may quickly drop CC in addition to a partial replacement.
    Jun 2016
    Central Oklahoma
    56
    Oklahoma
    Run pump 24/7
    Jun 2016
    Central Oklahoma
    56
    Feel less confident of the Cya test..
    Run pump 24/7
    Pool Tool's Avatar
    May 2014
    757
    CYA gives that feeling the most. The nice thing is that you can test it then pour the mixture back into the mixing tube and repeat it as many times as you like. I even store mine overnight and repeat it the next day with the same mixture. My results usually start to align and raise my confidence.
    In general, hold the graduated vial with only two fingers at the top, at waist level, with sun at your back but with strong sunlight. Basically, you are trying to maximize the amount of sunning hitting the mixture without the direct sun blinding it out. As the sun hits the CYA reagent in the water, it clouds the dot. I find it easier to pour a little in, look around then glance back at the dot. Then add a little more, look around and glance back repeating until its gone. This helps rest my eyes between and keeps the dot from reappearing.
    Jun 2016
    Central Oklahoma
    56
    Thanks for the tips on that.. Very cloudy now.. Drained about 4 inches out and now adding.
    Run pump 24/7
    DFW, TX
    24,483
    Ok, definitely want CYA at 80. Pour the mixture back and forth 4 or 5 or more times and check repeatedly until you feel good about the number and then round up.
    Jun 2016
    Central Oklahoma
    56
    I feel like it is more in between 70 and 80 now, but I did take a bit of water out.
    Run pump 24/7
    Jun 2016
    Central Oklahoma
    56
    Added my 4(8.25%) 121 Oz bottles of bleach. When should I test again??
    Run pump 24/7
    Pool Tool's Avatar
    May 2014
    757
    You can test anytime at any time. The beginning of slam the fc can drop quite fast. But definitely check before bed and add back to your slam target.
