Thread: Concrete on top of Liner Falling into my Pool!
    I have a line of concrete between the top of my liner and the top of my pool. The concrete is starting to fall apart and ends up at the bottom of my pool! I'm looking to fix it this weekend. Is it just a matter of getting a concrete mix and patching these spots? Should I put anything over the concrete when I'm done? Thanks!
    35,000 gals. vinyl pool, SwimPure SWG, Hayward 1HP Pump, no heater
    Long Island, New York
    wjr75's Avatar
    Jun 2013
    IL
    836
    Re: Concrete on top of Liner Falling into my Pool!
    Looks like you need tuck pointing done. I had some masenate pro's do my hot tub last year. They actually chip some of it out first so the new stuff will bound to it.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    How tall is that concrete? A couple of inches? Definitely knock out any loose material first. I think I might be tempted to use some Mortar mix instead of concrete. That is a pretty messy job. Rig up something to catch the spills, there will be plenty. I am halfway through tuckpointing some brick and it is a beating! It is an art to getting the right consistency, putting it up, getting it to stick and smoothing it at the right time. I am no mason! But, if you take your time and are patient you can have a good outcome. Buy a tool that fits that width for smoothing.
    Feb 2016
    Atlanta, GA
    145
    I feel like you could even do a small tile line with one inch tiles
    DFW, TX
    24,509
    Nice idea. That would be easier to backbutter the tile and then grout.
