Thread: How much HP for pump?
    May 2014
    Illinois
    10
    I need a pump for a 32x16 ft above ground oval pool. It's roughly 4.5 ft deep so about 15,000 gallons. Is there a recommended HP I need? 1 hp, 1.5hp, etc?
    32'x16', 14K gal, AG vinyl, sand
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: How much HP for pump?
    3/4 or 1HP should be plenty. My pool is a 20X36 IG and a 1HP is more than enough.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,484
    A two speed would be best. You can run it on low most of the time and use about 1/4 the electricity.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,775
    +1 to what John and pooldv said.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
