Thread: A&H Super Washing Soda Disaster
    Jul 2016
    Branchville, NJ
    1
    Hi I have a small above ground pool (about 6000 gallons). I've been having difficulties getting the PH and TA balanced. Someone had suggested A&H Super Washing Soda. I tried it and now the water is pretty much perfect in PH & TA, but now it's SUPER CLOUDY. I've been running the skimmer, even dropped the robot in there and no go. We've now been about 4 or 5 days without pool - Kids are about to kill me. I tried the HTH clarifier, but doesn't seem to work. Did I use too much Super Washing soda? Is there any fix in site?
    Any thoughts ideas would be great. Kids are digging my grave as we speak.
    Thanks!
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    885
    Re: A&H Super Washing Soda Disaster
    Welcome to TFP
    Often cloudiness is caused by algae. How are you testing your water?
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    Jun 2014
    15,233
    Hello and welcome to TFP! For us, it's almost impossible to know what might be happening without some reputable water test results. We recommended either a TF-100 (link below) or Taylor K-2006C. Do you have either of those to post test results with so we can see your numbers?
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    Cloudy water is usually due to the lack of chlorine.
    Can you post up a full set of results like this:
    FC
    CC
    PH
    TA
    CH
    CYA
    What test kit do you have?
    Can you update your signature with the specifics on your pool. Here are the details we need: Pool School - Read This BEFORE You Post
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Jun 2014
    15,233
    By the way, in case you didn't know already, washing soda raises pH. Not sure if that's what you wanted to do, but knowing what your test results are will help us significantly.
