Thread: 1 lb DE Scoop = 1/2 pound of DE??
    Jun 2016
    Plattsburgh NY
    13
    Good Morning,
    Probably a noob question, but I am confused as to what the correct measurement of DE is for my particular filter. I have a Pentair ST50 filter, which is approx. 48 square feet. The filter guide says a 1 pound coffee can covers approximately 5 square feet of filter area, so I am looking at 9-10 scoops for my filter.
    I bought a 1 pound DE Scoop off of Amazon... http://www.amazon.com/Blue-Devil-B83...ct_top?ie=UTF8
    However this 1 pound scoop says one scoop = 5 square feet of filter area (just like the coffee can). If that is true then I just paid 10 bucks for a slightly prettier coffee can lol. You would think that a 1 pound DE scoop would actually give you 1 pound of DE. Very confusing!
    15,000 gallon above ground pool w/ vinyl liner
    Pentair Star(50) DE filter
    Unknown pump manufacturer, seems to be working fine
    Pool installed in 2010
    Taylor 2006-K test kit
    JoyfulNoise's Avatar
    May 2015
    13,215
    Re: 1 lb DE Scoop = 1/2 pound of DE??
    Yep.
    I have an bright orange DE scoop that is much bigger than a coffee can and holds 1-lb (roughly) of DE per scoop. You can find them in Pool Stores. I would return that scoop and just go get one from the pool store unless you don't mind putting in extra scoops.
    Matt
