Results 1 to 8 of 8
Thread: 1st Test Results with TF100 Kit - What should I do now?
    Jun 2016
    Rochester/NY
    5
    Daily Test:
    CL = 5
    PH = 7.2
    Weekly Test:
    FC = 11.5
    CC = 1.5
    TC = 13
    CH = 250
    TA = 100
    CYA = 100
    This is my 1st year with a pool. It came with auto chlorinator using 3" tabs.
    24K gal, IG vinyl, Emerson 1hp pump, Hayward S-200 Sand Filter, Hayward automatic chlorinator, Baracuda cleaning robot
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    880
    Re: 1st Test Results with TF100 Kit - What should I do now?
    You have a couple of concerns- firstly you have a high CYA which is being caused by the tabs you are using for your chlorinating. You need to consider a drain of your water to bring this level down and pull the tabs -start using bleach or liquid chlorine.
    You also have a high CC which is also a concern. How does the water look?
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,237
    Welcome to TFP! Good to have you here And thanks for posting your test results.
    How does the water look to you? Could you post a picture looking down at your steps, or with your brush or cleaner in the deep end? Your numbers look good except for the combined chlorine.
    CYA may be higher than 100, so I'd recommend the diluted test. See #9 in Pool School - CYA
    Haha, simultaneous help from Aus! Jezza will be awake longer than me, and he has you covered!
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Jun 2016
    Rochester/NY
    5
    The water looks very clear.
    I will do the diluted CYA teat today when I get home.
    So I should stop using tabs completely?
    What should my CC be?
    If I turn chlorinator of completely, I assume CC will drop & when desired level is achieved, I can maintain with bleach added directly to pool?
    Jezza's Avatar
    Jan 2015
    880
    Yes- you have to stop using the tabs now- they will continue to add CYA and that will mean more of a water drain to get it down to a reasonable level if it is astronomically high. Use bleach and the Poolmath tab to calculate your additions.
    CC's should be <0.5. CC's are brought down by chlorine and sunlight although if you have organics in your pool it could take a possible SLAM to get on top of it and bring it down to an acceptable level.
    But your focus now should be on establishing your actual CYA as first priority.
    K-2006
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Just to elaborate, CC's are not something that is directly added to your pool. Think of CC's as spent FC. They are a byproduct, a leftover, of FC oxidizing organic material. A healthy, well balanced pool will have less than 0.5 ppm CC's. As Jezza noted, sunlight will remove CC's, this is why leaving a cover on can cause a high CC reading temporarily, as well as raising FC levels will eliminate organics in the water and reduce CC production.
    Word of caution tho, do not try to use CC's as a measure of your FC effectiveness, i.e. "my pool is cloudy and I raised FC, but I am not generating any CC's so it must not be algae." Measurable CC may or may not be formed when FC kills something or it may simply be burning off by sunlight (UV) prior to sampling.
    FC = Good, CC = Bad. Like your case with CC of 1.5, it is telling you that there is something in your water that your FC is fighting necessitating a SLAM - even when your water is otherwise clear!
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Jun 2016
    Rochester/NY
    5
    Wow, very helpful - thank you.
    So are my FC's O.K.? Too Hi?
    I am going to stop using my chlorinator. Should I start to add bleach immediately ow wait until FC's measurement requires additional chlorine?
    What is the sweet spot for FC's?
    Pool Tool's Avatar
    May 2014
    757
    Here is the FC sweet spot based on your CYA level. Pool School - Chlorine / CYA Chart
    Wait until you can do the diluted CYA test. It may come back higher, which would definitely necessitate water replacement.
    Provided your CYA stays at 100 ppm, your FC of 11.5 is pretty good. I would prepare to be able to add bleach/chlorine (same thing) within a day. Do not let FC get below 7 or 8 ppm.
