Thread: Getting Started for this year
    Jun 2015
    Davenport, Florida
    14
    Hello All
    I drained my gunite pool over the "winter" season here in florida, pressure washed it, etc
    i refilled it with city water last weekend
    here are my chems
    FC 13
    CC .5
    PH 7.5
    TA 180
    CH 125
    CYA 30
    I am asking to get a double check of what i need to do to my water
    it is totally clear, but lacks the diamond sparkle
    i know i need to lower the TA and raise the CH
    pool math says to lower the PH to get the TA lower , then aerate to raise the PH
    to raise the CH i need to find the calcium chloride 389oz is that something you add slowly?
    i did add more cya to raise it to about 50 as the pool gets full sun most days
    many thanks
    12,500 In Ground Gunite Free Form, 1 Skimmer 4 Returns
    Screened enclosure, TF-100 Test Kit, Speedstir
    Sta-Rite 1hp Pump
    Pentair 100SF Reusable Filter
    Haywood Cl100 Auto Chlorine Feeder (currently disabled)
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Getting Started for this year
    you are correct on TA, PH and the CH.. the CH may cloud your pool for a day or 2 after adding, you can do it in smaller amounts, it may take some time to get that sparkle back, some of it is from filtering and some is from your CC and new fill..
    I hope this helps
    Jun 2015
    Davenport, Florida
    14
    I should be able to wait till after the holiday to add the CH? how long after adding the acid will it be usable again?
    Sta-Rite 1hp Pump
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    894
    Give the acid about 15 mins to disperse throughout the water with the pump on and you'll be good.
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
