Page 1 of 2 12 LastLast
Results 1 to 20 of 34
Thread: I can't be the only one with this issue
    May 2016
    MD
    195
    Maybe no one tests around different areas of the pool, or maybe I just stink at doing the FC test in general....
    One morning after letting the FC drop so I can test PH i came up with FC 6 Figure I do the test right, but I was like, that is way to low... I tested the same spot again. Got an FC of 8 which is where it should have been.
    Tested the other side of the pool and got FC 10.
    Today Tested one spot. got FC 8. I was like, this is wrong... Tested another spot after running the pump for 20 mins... after it sitting all night not being on, and got an FC 11.
    So either my pool is just weird, or it has the worst circulation ever. Or i really suck at doing the FC test. I have the speed stirrer... and CYA of 100 for those questioning the FC
    IG, 25k gallons, 20x40 ft, Plaster, Pentair sand filter, variable speed pump, have a well, TF-100 test kit, Speed Stir
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: I can't be the only one with this issue
    A water sample for testing should be collected after the pump has been running for at least 20-30 minutes. When doing this, I've collected water samples from various areas and haven't noticed any outlying results.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Sounds like circulation to me, throw a ping pong ball or empty plastic soda bottle in and see what is does..
    30,400
    FC is FC period. It cannot go up unless you bring it up. It will ALWAYS go down....how fast depends on a lot of factors.
    Since those facts are pretty absolute, operator error is usually the cause.
    Do you understand exactly at what drop of R-0871 the test has ended?
    domct203's Avatar
    Jun 2015
    CT
    3,577
    Quote Originally Posted by Puppiesonacid View Post
    It's most likely a combination of poor circulation issues and user error.
    When you test FC, are you certain you are using a consistent sample size, and holding the R-871 bottle as vertical as possible and allowing the drop to naturally form & release from the dropper tip? I count my drops like I count my seconds, 1-one thousand, 2-one thousand, etc to try and maintain a 1 drop per second rate. I also use the Sample Sizer and Speedstir, which helps to remain consistant with my testing.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    May 2016
    MD
    195
    When it is totally clear.
    I do let the drops fall, but sometimes it stalls so i squeeze a little bit. I do have the stirrer.. cause i stink at doing it myself without..
    30,400
    Pretty close.. You continue to add drops until the LAST drop you add makes no further color change. Then you subtract that drop.
    Hold the bottle vertically and allow the drop to fall off the tip each time. The more you do it, the easier it gets.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Some things you can do to ensure you get consistent results are to pick one location and depth to collect the test sample from. For me its about 3 feet away from the return, elbow deep. When conducting the test, make sure the reagent bottle is completely vertical and allow the drop to form and drop off the tip freely with minimal pressure to ensure consistent drop size. Tilt the reagent bottle horizontal between drops while you swirl the sample being tested. Always draw the sample after the pump has been running at least 10 minutes.
    You can check your circulation with a few ping pong balls. Just drop them in at different spots in the pool with the pump running and see how they circulate. Adjust your returns to direct flow to any dead areas.
    Love TFP? Become a
    TFP Supporter!
    May 2016
    MD
    195
    I try to do that vertical thing, but they really do just stop after a few drops from coming out on their own.
    And I will remember that. Maybe my clear isn't what I think it is.
    Quote Originally Posted by zea3 View Post
    Would be nice to adjust the returns, but they are just PVC pipe shooting back into the pool at 3 spots on the same side 8 feet apart
    May 2016
    MD
    195
    Just tried again and got 11... after adding half a gallon of bleach 20 mins or so ago with pump running. I have to go buy some ping pong balls. it is meant to flow around as in counter clock wise, so all the returns push right and push the water around length wise.
    I know when i sit in a float it works like this as it is sort of like a lazy river i go slowly around and around. i got a variable speed pump, so i guess i am not running it as fully as a 2hp used to run, though doing the math at 1400 to 1500 watts would be equivalent.
    just looked up returns on amazon... go figure, I can put stuff in the pipe... guess these people really were freaking lazy in the end of their divorce and got rid of things as i never seen them laying around, or they ever had them
    Jul 2013
    Fletcher, OK
    3,353
    they are eyeballs and will bring your pressure up depending on what size you get, with 2, 3/4 inch eyeballs on my returns on high I get 15 PSI... with 1 eyeball and my sprinkler/waterfall i get 10 PSI
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    I know this is the appropriate method for titration tests of TA and Calcium Hardness where the test is over at that point. But with the FAS/DPD if you continue on to test for CC (adding 5 drops of R-0003, see if pink returns, then titrate once again with R-0871 to once again return to clear) wouldn't you be one drop over already when doing this part of the test and possibly get a 0 CC reading when you may indeed have CC's?
    An example may be clearer... Say I am using a 10ml sample:
    - One scoop powder - solution is pink
    - 10th drop of R-0871 turn solution clear so I STOP and Record FC as 5.0
    - add 5 drops of R-0003 and solution turns slight pink
    - add 1 drop of R-0871 and solution turns clear - Record CC as .5
    In example above a TOTAL of 11 drops of R-0871 are in the vial at the end of test.
    Now do SAME test with the "LAST drop makes no further change" method (changes in italics):
    - 10th drop of R-0871 turn solution clear. On 11th drop the is no further change, so I subtract that and - Record FC as 5.0
    - add 5 drops of R-0003 and solution does Not turn Pink
    - No need to titrate so record CC as 0.0
    In this example a TOTAL of 11 drops of R-0871 are already in the vial at the beginning of test, hence the reason my R-0003 never turned solution back to pink
    One method give me 0.5 CC, the other gives me 0.0
    Said in other words, if I always go 1 drop over and subtract it out, then won't I always already be "1 drop into" my CC titration prematurely?
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    Jun 2014
    Houston, Texas
    475
    HA - I am the exception to the rule - my FC has gone UP!!!! LOL
    19k SW IG
    Wet Edge pebble tech = new 5/16 (replaster)
    Hayward variable speed pump (new 6/17) /Shark for cleaning
    New - filled 10/18/14 - TFP 100 test kit
    May 2016
    MD
    195
    I can't figure it out... I am quite a perfectionist when doing the test, as much as you can be anyways, and still come up with 2 different numbers in different spots. this was after the pump was running for an hour before i got home from work.
    I am sure it has to do with me, or my pool is just stupid. I just can't think of any other way to do it... i even use 2 scoops of powder both times, get the line the same height as best i can... and use the speed stirrer... let the drops drop themselves when they will, or very very lightly squeeze till they come out.
    got 8 in one part near the returns and 9.5 away from them... getting water from about elbows length in both places
    May 2016
    Swansea MA
    62
    I was having the same problem at first and started using just a tiny bit more of the powder. ( a good heap ) It seemed to help me try it out and see.
    24 ft round AG 12,700 gal. vinyl
    Doughboy Sequel II Rotary DE filter
    TF-100 test kit. 1st full season
    wjr75's Avatar
    Jun 2013
    IL
    836
    Make sure you have the ribbed tip inside. I just bought a refill and it didn't have it. I read an earlier thread about this problem and swapped the old bottles tip on the new bottle. I don't think the drops should be coming out by them selves without a little pressure to the bottle.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    May 2016
    MD
    195
    Quote Originally Posted by wjr75 View Post
    It is the right bottle tip. The first one I got was right, the second one was wrong, so when the first was empty i switched them.
    Maybe it is the amount of powder... almost wish the spoon was bigger... and more precise.
    Editing here... I tested it this morning after getting 8 and 9.5 last night, I got a 10.
    I think the other part is i need to run the pump faster longer...
    Jul 2013
    Fletcher, OK
    3,353
    I do not think it is how you are testing, it sounds exactly like circulation.. after you brush the pool and swim I bet the FC levels will be the same everywhere
    May 2016
    MD
    195
    Quote Originally Posted by cowboycasey View Post
    Yeah... The learning curve I just assume things are crazy cause how everyone else says they run their pumps for 15 mins and check again... mine may need to run for an hour or so to do the same thing.
    I basically have it run very slowly during the day to keep the water moving, and keep surface pollen at a minium, which I seem to get a lot of... and then at night for an hour it bumps up to 2 HP, and then shuts off over night, and at 530 am it kicks in to 2hp again for 2 hours before running at like 1/2 HP though the sunny days
  20. Back To Top    #20
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    There are only a few possibilities to consider here.
    Testing error, dosing error or circulation
    FC was higher after adding than you thought if you didn't test after
    FC wasn't fully mixed in when you tested if you did test after
    Your neighbor snuck over and added some bleach in the middle of the night
    Pump on high and brushing can eliminate the mixing question
    Using the 25 ml sample reduces the margin of error
