Thread: Question about muratic acid...
    Jun 2016
    Manteo north carolina
    50
    I can not find the strength of my muriatic acid on my bottle. I got it at Lowes its the green label bottle. I also need to add cya and salt. Is it ok to add all or should I space it out. My cya is 30 trying to reach 70. My ph is 8.2.
    Above ground intex 24x 52 Swg with sand filter pump. Well water. New started the end of May. 11,600 gallons. Test kit TF100
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Question about muratic acid...
    According to Lowe's web site (Shop Crown 1-Gallon Muriatic Acid at Lowes.com), the green bottle is half-strength. Specs listed on web site are 10° baume (15.725%).
    They also sell a blue-labeled bottle for the same price that is full-strength 20° Baume (31.45%). If you haven't opened the green bottle, I would exchange it for the blue-labeled bottle.
    The green bottle is marketed as an environmentally-friendly alternative. But at the end of the day, you will need the same effective strength of MA to reach your target pH level meaning you will be using twice the amount of product vs. the blue-labeled product. Really don't see the benefit of the green bottle except to the mfr's bottom line.
    Jun 2014
    15,004
    Here are a couple examples:
    Muriatic Acid (Home Depot):
    Muriatic Acid (Lowes):
    Jun 2016
    50
    The brand I have is Jasco Green muriatic acid.
    jasnovanorder's Avatar
    Jul 2015
    Hamilton Michigan
    201
    Quote Originally Posted by blsobx View Post
    Per the Jasco website it is 20%
    Jasco | Jasco® Green™ Muriatic Acid.
    Intex AG metal frame vinyl sides 10,400 gal. 3000 gph intex pump with 16" sand filter
    My Slam
