Thread: Wouldn't it be a good idea if you could shoot the heat pump's cold air in your house?
    Apr 2016
    Tracadie, New Brunswick, Canada
    35
    Just looking at the heat pump and seeing all that cool air coming out the top of it going to waste, while I am paying to air condition my house. Why wouldn't they make an adapter of sorts to route the cold air flow inside your house. I know it would make the heat pump slightly less efficient but wow it would be sweet.
    27' Above Ground Salt Water Pool (52"), 67380 Liters
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Wouldn't it be a good idea if you could shoot the heat pump's cold air in your ho
    They actually make a system that does exactly that ☺
    Heat Recovery Pool Heater | Compare To Solar Pool Heater | HotSpot Energy LLC
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,818
    You might turn you house into an ice box if you couldn't control the flow of air some how. Have you tried leaning over the top of the heat pump when you are hot and sweaty from yard work? Its amazing how quickly that will make you cold.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Marty D's Avatar
    Jun 2016
    Quogue new york
    146
    I was thinking the same with my 140 pentair heat pump. That pump is Pushing out cold!!! I need to look into this. Smart thinking.
    Apr 2016
    35
    You could have a ducting system where it could either direct the cool air inside your home or to the outside or any mixture in between.
    Quote Originally Posted by cowboycasey View Post
    That would be great for people with outside air conditioning to recoup the heat released. I was thinking more around the lines of taking the cool air coming out of my pool's 110,000BTU heat pump and ducting it inside my house.
