Results 1 to 8 of 8
Thread: Best place to get chemicals?
    Mar 2016
    Spring, Texas
    47
    Thankfully the pool builder left us with a pretty nice startup kit that's kept is in chemicals for almost two months. We are however starting to run low on muratic acid, and need to buy baking soda, bleach, borax, etc. Figured I'd just grab most of it at Walmart, but one of my neighbors mentioned she picks up some stuff at Costco and has a Subscribe and Save at Amazon for some things as well. I also heard someone else mention they buy Muratic acid at ACE HW? I would have never thought to look there. So who does generally have the best prices? And how much should I expect to pay for the various chemicals you typically need for maintaining the pool?
    21000 gal IG Pebble Sheen (Blue Surf), Pentair quad DE filter, Sta Rite Intellipro VS pump; Paramount PCC-2000 inground cleaner; Installed May 2016.
    Jan 2012
    'burbs of Augusta, Georgia
    7,373
    Re: Best place to get chemicals?
    Muriatic acid is from Lowes or Home Depot. In the paint department. 31% 20 baum. About $7
    You don't need to buy baking soda or Borax yet, until you *need* them. Some never need them. IF you decide you need them get the big honking bag of Arm and Hammer baking soda (even shows a pool on the front) at Costco, Walmart or someplace like that. I think I paid about $4? it lasts forever.
    Borax is from the laundry aisle at H.E.B.. about $3
    Bleach is the unscented, non-specialty, plain bleach.. 8.25% or greater. Prices vary so compare. Don't buy at Lowes or any place that stores it in the heat, sun or outside. Make sure you check the date codes (Julian dates usually) for the freshest stuff. Bleach loses potency so you don't want to store more than a month's worth at home.
    CYA you can get in 4 pound jugs of granular at Lowes or Wallyworld. Liquid (double the price) is available at Leslies's.
    Mar 2016
    Spring, Texas
    47
    Thanks for the run down! I asked for Muratic Acid at Home Depot today and they looked at me like I'd lost my mind... they sent me to the pool section & I found PH down kind of stuff, but no pure MA. Didn't think to look in the paint dept. Now I know for next time.
    On the Baking Soda front I was in Walmart so grabbed a 12lb bag from the 'pool section.' It was $7.46. Found 4lb boxes in the laundry isle for $2.18 each. So would have actually been about a dollar cheaper to pick it up in the laundry dept, but since needed 9lbs I went ahead and bought the resealable package to make it easier to store.
    Mar 2015
    South Texas
    411
    Just an FYI, I have never once had to put Baking Soda in my pool. I can understand needing to stock up on MA to some degree, but I would leave the other stuff until you actually need it, which may be never
    15,000 gallon free form Viking fiberglass pool. Hayward Star-Clear Plus C12002 cartridge filter. Hayward Swim Pure Plus T-15 SWG. Testing with TF-100 Kit. 2 speed 1.5HP Supreme pump. Dolphin Nautilus robotic cleaner
    30,432
    Don't be in a rush to save big on chemistry using TFP. You will find that you simply won't use very much. We would rather have you understand why you do or don't have to add than tossing in stuff when you don't know the outcome. Stay with us....pool management is about to get easier and easier.
    Rsmith's Avatar
    Apr 2016
    Central Md.
    110
    I found the MA at Home Depot on a stand alone rack down in the lumber section. It was in boxes of 4.
    Central Md. 37 X 21 24K IG Custom Gunite with Anvil Quartz finish. Raised Spa.
    Sta-Rite Natural Gas Heater. Intellichlor IC-40 SWG, Sta-Rite 450 sq ft. Cartridge Filter.
    Pentair 1.5 Hp Variable Speed Pump. TF100. Dolphin Z-5. First swim 5/26/16
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    MA/HCL is in the paint section at my Lowes...although I haven't been a fan of the particular line of product they sell. HCL and Jacks Magic are the two products I still venture to the pool store for. Plus it let's Jan look at the inflatable flamingos and alligators.
    15' x 29' 10,300 gal w/ spa, IG-Plaster (Stonescapes Tropics Blue), 2spd WhisperFlo pump (1.5hp WFDS-26), Pentair Clean and Clear CC200 cartridge filter, Pentair MasterTemp 300BTU heater, Clear o3, RS-8 iAqualink
    Apr 2013
    Sacramento, CA
    2,769
    At HD and Lowes the MA and chlorine will always be about 50 feet apart. So find the pool stuff and you find the chlorine. Then check around the adjacent area and you will find the bulk MA.
    It is unsafe to store them adjacent to each other. The managers know that but many of the clerks have not been trained. So if they areconvenetly close tell a manager and they will fix it.
