Thread: Vacuum Hose Conversion Coleman
    Jun 2016
    Arnaudville
    1
    How did u hook up the vacuum without a skimmer... I'm having serious issues.. due to the fact that most vacuums hook up to a skimmer..my sand pump has a small basket on the motor part but how could I connect the two. I'm confused ��
    mod note: thread split from here, Hose Conversion Problem - Coleman 16' x 48 and Best Choice Products Pump/Sand Filter
    Quote Originally Posted by Deej4224 View Post
    I purchased an 18 x 52 Coleman pool from Walmart and a Clear Bay (I think) sand filter/pump from Leslie's Pool. The instructions that came with the new sand filter/pump had me in tears. I had to quit trying and go back to it the next day. I went to Lowes and found a few parts to get it connected. The T is leaking a bit but I did the best I could without knowing a darn things about what I'm doing. Good luck!
    Quote Originally Posted by Jimmy2015 View Post
    That's what I feared. I'm still interested in any solutions that anyone might have.
    Does anyone have any experience hard plumbing an above ground pool? If so, what sort of a PVC connection will work to hook up an in-pool auto-vacuum? That might not work either, but it's worth a shot.
    http://www.amazon.com/Hayward-500-Ab...g+pool+sweeper
    mulia's Avatar
    Jul 2011
    NE Ohio
    100
    Re: Vacuum Hose Conversion Coleman
    If you don't have a skimmer, you should be able to shove the vac hose right into the inlet fitting, which is underwater. I've changed my inlet and outlet fittings to hayward brand, but I connect my vac right to the inlet and it works better than attaching in the skimmer.You must unscrew the screen on the inlet first,if you have one on the inlet.I don't know how to post pics, but on amazon for that vac,in comments is a pic of exactly what you need to do. Good luck!
