Thread: Excited to Test!
    JesseSchmidt's Avatar
    Jun 2015
    Fairfield Twp, OH
    216
    Wink Excited to Test!
    So I was way too excited to get my TF-100 and speedstir in the mail yesterday. I didn't have time to test yesterday evening but I did today.
    FC 4.5
    pH 7.5
    CH 100
    TA 80
    CYA 50
    By some luck, having used dip strips since we bought the house/pool a year ago, everything is in pretty good shape! I figured it couldn't be too bad because the water is crystal clear. The down side to water this clear is that people can see every spec of dirt on the bottom of the pool when I haven't vacuumed in a while!
    Thanks to the knowledge I have gained on here in the last year, this newbie has been able to keep a pool in good shape even without good testing! But now I KNOW the water is in good shape!
    26k Gal IG vinyl, Hayward Super 1HP, Hayward Pro Series S244T Sand Filter, TFTestkits TF-100 w/ Speedstir
    Links: TFPC for Beginners / ABCs of Pool Water Chemistry / GETTING STARTED / PoolMath / SLAM / TFTestkits / Chlorine/CYA Chart
    38,539
    Re: Excited to Test!
    Looks pretty good ... likely the CC test is 0?
    You might bump the FC up at bit to stay above the minimum for your CYA level.
    Jun 2014
    15,292
    It's like Christmas in June when you get your first TF-100 w/ Speed Stir! Yeah! Oh, and as for this comment:
    I'm afraid you're stuck on that one. It has gotten me in trouble MANY times. "There's junk down there. Don't you need to vacuum?" Ugh.
    Jun 2015
    Fairfield Twp, OH
    216
    Sorry, forgot to list the CC but yes it was 0. Also, used the numbers to find the amount of CL to add to get to target and dosed. I feel like such a dork for being excited about my chemistry set!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    We won't judge you!
    Jan 2012
    'burbs of Augusta, Georgia
    7,373
    Someone once said if you want to really, REALLY see what needs to be vacuumed, do it at night with the lights on. OMG. Its awful... you see specks all over and floating... if you have an OCD tendency it will drive you nuts!!
