Results 1 to 7 of 7
Thread: Chlorine
    Jul 2015
    Crosby, TX
    6
    How much 10% liquid chlorine for 18,000 gallons. Currently shows 0 chlorine in it
    24' x 54" - 18K gal. - AG vinyl liner - 1.5 Hp pump Pentair 22" tank Zeolite
    TF - 100 test kit - April 2014 - Crosby, TX
    Thank you, Ree-Ree
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,871
    Re: Chlorine
    Hi,
    That's impossible to say since we don't know what level you are trying to target and your target would depend on your CYA number and if you are working with a fresh fill of sparkling water.......or trying to clear up a cloudy algae outbreak.
    You can use pool math which has a link at the top of the page to put in your "now" numbers and your target numbers.
    Can you post up a set of good test results.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Jul 2015
    Crosby, TX
    6
    Re: Chlorine
    Not a fresh fill. I think I am fighting a cloudy algae break out. I will test tomorrow. Tonight I just done the strip.
    38,547
    Re: Chlorine
    Do yourself a favor and throw the strips away.
    What other test kit do you have? Is it one of these: Recommended Test Kits?
    OH, just saw the signature. That will give you an idea of the CYA, but it is not going to be sufficient to follow the ShockLevelAndMAINTAIN Process. You need the FAS-DPD chlorine test.
    Jul 2015
    Crosby, TX
    6
    Re: Chlorine
    I have to change my signature, LOL! I do have the $60 set that was recommended by this site.
    Thank you, Ree-Ree
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Re: Chlorine
    Great! In that case, what is your CYA?
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jul 2015
    Crosby, TX
    6
    Re: Chlorine
    I am at work right now. but when I get home I will be able to test it with the TF - 100 kit. Will let you know.
    Thank you, Ree-Ree
