Thread: Pool Help!!
    Jun 2015
    New Jersey
    24
    Pool Help!!
    So my pool was cloudy yesterday so I shocked the pool with the recommended amount of bleach. When I saw the pool this morning the water was nice and clear. I came home from work today and the water was still clear but I saw some green on the pool floor which means I still have algae. I tested the water again tonight and my results were:
    FC - 5.8 (dropped from 28)
    CC - 1.8
    PH - 7.6
    CH - 300
    TA - 150
    CYA - 80 (thought it was in the 70 range until someone taught me how to properly do the test)
    My problem is I will be gone for the weekend and won't be back till Monday. I'm not sure how to approach this. I know it's time for my filter to be back washed and that will be first thing I'll do tomorrow before I leave for the weekend but I'm not sure if I should slam before I leave or use an algecide and keep the floaties in the water till I come back to deal with the problem. I know I should first get my CYA down before I do anything but will not have the time tomorrow to drain and fill. Any advice on how to approach this would be most appreciated. FYI pool was green when I opened and my pool store recommended that I shock till the water cleared. I shocked 3x with chlorine granules which got my water clear but also jacked up my CYA. This was all before I got the proper info on CYA. I desperately need help from the pool veterans.
    Pentair Quad D.E Cartridge Style Filter
    Pentair Multiport Valve SM-20-3
    Hayward Pump
    Jandy Energy Filter
    Gas heater for Spa and pool
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Re: Pool Help!!
    I'd take the FC to SLAM level for your CYA--call it a day-----and then work on it full force when you get back.
    Jun 2015
    New Jersey
    24
    Re: Pool Help!!
    Would using more then the recommended amount be a bad thing. According to CYA chart I should get my FC to 31. If I went a little over that would that mess up or stain my pool?
    Hayward Pump
    Jandy Energy Filter
    Apr 2010
    East Texas
    9,659
    Re: Pool Help!!
    With algae and your CC, it will disappear pretty fast since you can't stay on top of it. Don't bother.
    Jun 2015
    New Jersey
    24
    Re: Pool Help!!
    Got it appreciate the advice
    Hayward Pump
    Jandy Energy Filter
