Thread: Yellow spot/stain on spa control
    Jun 2016
    Syosset, NY
    6
    Just openned after 4 years 340 gallon spa.
    Went thru decontamination process..purge and superchlorination to 70ppm.
    I am in the process of increasing CYA with dichlor (27 of 34 ppm of dichlor)
    Starting seeing yellow spots stains on control panel. See pic.
    Chems: tf100
    Temp 100
    Fc : 10 (to much dichlor today)
    Cc .5
    pH: 7.8
    Ta 70
    Ch 150
    Cya 24 ( based on dichlor added)
    Anyone have any idea?
    38k (L - Shaped) Vinyl. 1.5hp Pump, DE Filter
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Yellow spot/stain on spa control
    looks like tanning lotion to me...
