Thread: Help with low chlorine level - algae keeps coming back
    May 2013
    Bensalem, PA
    13
    So I've been fighting with algae growing in my pool for a while now. Decided to buy a test kit and read some articles in the pool store as well as watching youtube videos on how to properly test my water.
    About once a week I have to vacuum the pool to get the algae off the bottom and backwash.
    I have a 24' round 4' deep above ground pool - 13,500 gallons with a DE Hayward filter. Chlorine is delivered through a floater with 3" pucks that I usually have 3 in at a time.
    I just did a test of all the levels twice to make sure I have them all correct, here are my results.
    Ph - 7.4
    FC - 0.5 to 1
    CYA - 70
    CC - 0
    TC - 2
    I've never used bleach or liquid chlorine before, and I just want to get some advice on how much I will have to add to get the FC in the 8 range target (as noted in the CYA chart).
    Thanks!
    Mar 2016
    San Diego
    17
    Re: Help with low chlorine level - algae keeps coming back
    I'm new, but I do know, first thing you'll need to do is shock your pool. Your CC is 0.0 but you deal with algae every week?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Welcome to TFP!
    To kill algae we follow this process, SLAM
    Jan 2012
    'burbs of Augusta, Georgia
    7,362
    I'm not sure what test kit you've used but if you do the math- TC 2 minus FC 1 = 1 to 1.5 CCs. Your pool test results are not looking like algae killing range.
    For a CYA of 70 (assuming that is correct) your FC should be 8, so with daily FC loss to the sun of aprox 2ppm, you should aim for 10ppm. Then when it drops you won't be too low which encourages algae growth.
    Just so you know, 20 ounces of 8.25% bleach will raise your FC by 1ppm.
