Thread: Question about Blue stains in pool
    Jun 2016
    Fremont
    2
    Hi, I'm new to the forum so not sure where to post this, I just drained my pool to clean, and our pool has had these blue stains on the walls for some time, I am wondering what these are and how best to remove/clean them while I haven't refilled my pool yet. I've shown these pictures to our local pool store and they said its calcium deposits.
    I've looked around but not sure how to remove these, does muriatic acid help to remove these stains? or is there a better method? Any help would be appreciated
    Thanks
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Question about Blue stains in pool
    Welcome to TFP
    that sure looks like calcium scaling... I am not up on everything with it but this is in pool school
    Pool School - Calcium Scaling
    the last sentence: The only reliable solution for removing calcium scaling is a full drain and acid wash.
    Jun 2016
    Fremont
    2
    Thanks for the reply!
    Question about the calcium scaling, is there any harm in leaving it as is and not doing the full drain and acid wash? It would take a bit of work and I'm wondering if leaving it alone is an option or if it's something that needs to be treated
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    It is fine to leave it alone. Better probably because an acid wash is a pretty aggressive treatment and will shorten the life of your plaster. Keeping your CSI negative (use Poolmath), -0.3 to 0, will prevent future scaling. Keeping CSI -0.6 to -0.8 and brushing with a stainless steel brush will slowly remove the scale.
    More here, Pool School - Calcium Scaling
    If there are very rough spots you can sand them with wet/dry sandpaper to smooth them
