Page 1 of 3 123 LastLast
Results 1 to 20 of 48
Thread: Another build in DFW... far north DFW
    Jun 2016
    Savannah
    30
    Have been following along for several weeks now and our dig date is scheduled for next week Hoping for Tuesday!! We went with a small PB out of Denton, TX. Was recommended by a friend and after getting bids and interviewing three different PBs, he was our favorite. I just really want a place to chronicle the build!
    It will be 30 X 18 in-ground gunite freeform with a raised spa. We have a pretty small yard with an already existing cedar- arbor/gazebo that is shingled to match the house and has a concrete foundation so that will serve as our outdoor covered patio and where people will mostly hang when outside of the pool. We also have a screened in porch on the back of the house but it is smaller and narrower. We have an over-sized swing and a couple of chairs in there but no dining space. Plus it gets pretty warm in there in the heat of the day as only one side of it is open with the screens. We are lucky that we back up to a green-belt with tons of outdoor space the kids can still play in since we are losing almost all of our yard space. Pool will have a 6 foot tanning ledge and two barstools that will face the gazebo. There will be a weeping wall on the opposite side. It is a play or sports pool that will go from 3.5 foot to 6 foot then back to 4.5 feet deep.
    Posting but will edit to add drawings when I get them uploaded to photobucket.
    Jan 2012
    'burbs of Augusta, Georgia
    7,239
    Re: Another build in DFW... far north DFW
    Hey there CowboyMommy Welcome to TFP
    Your pool is going to only be 3.5 to 4.5 feet deep? Is that the desired depth of the pool or the water inside which is usually 6 inches less. Make sure whatever your desired water height is specified to your PB.
    Jun 2016
    Savannah
    30
    Quote Originally Posted by YippeeSkippy View Post
    No, sorry, I realized that I typed that incorrectly after the fact lol. It will be 3.5 feet to 6 feet in the middle then back to 4.5 feet at opposite end. I will try and edit it!
    I am not sure if it is okay to post the created images with the pool builder on them. I couldn't edit them to remove it. But if someone knows how, I will!
    Jan 2012
    7,239
    May I suggest you go for 4' to 6' in the middle then back to 5'. Deeper pools are way more fun IMO, and some folks have regretted that 3.5 depth later. And with those benches and the tanning shelf you have plenty shallow areas to hang out.
    Just a suggestion to consider
    Jun 2016
    Savannah
    30
    thx for suggestion, yes, will absolutely consider it and talk with family and PB about it. Thx!
    I am wondering if the 3.5 foot is to properly accomodate the barstools? I don't know but it is a good question to ask!
    Mar 2016
    Granbury, Tx
    36
    We just built a pool that is 3.5'-6'-4'. I can tell you from experience you probably won't be happy with the drop off to 6'. I am tall so I can touch everywhere. But my wife cannot. The decline down to 6' is pretty steep. Our pool is 34' long too. If I was going to go back and do I it all over I would go with 5.5' in the middle instead of 6'. Mainly because not everyone is 6-4 like me. The shallow areas are very small due to the gradual drop off to 6'. Just a recommendation.
    Matt
    19,600 Gallons, 34'x24' Cloud Shape, 3.5'-6'-4', 2 Skimmers, 4 returns, natural gray plaster, Oklahoma Flagstone, NPT Silverstone Ocean Blue waterline and maker tiles, Pentair IC40 SWG, Pentair FNS Plus 60 DE Filter, Pentair Intelliflo 2 VST, Pentair EasyTouch 4, Pentair Intellibrite 5g Color Led light, Polaris 280 cleaner, 1.5 ton moss rock waterfall, 785 sq. ft. exposed aggregate deck, and mosaic crab on bench, TF-100 Test Kit
    Mar 2016
    Granbury, Tx
    36
    I should say steep drop off to 6'. Not gradual.
    Matt
    Aug 2014
    Houston tx
    2,524
    At first glance, I thought your pool extended to under the covered area! I thought how cool to have a bridge to swim under! LOL!
    Even so, this is a great design! Is there a bench on this end of the pool?
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Jun 2016
    Savannah
    30
    Quote Originally Posted by Marlahoutex View Post
    yes, there is a bench at end starts right at end of weeping wall and goes around to middle. We kept this end mostly uncluttered since there is so much going on at the other end. Figured this would be the area our kiddos would jump in over and over again in. Can't wait to see that!!
    May 2016
    Prosper/TX
    9
    cowboymommy-sending you a PM
    ~Rene
    17/28 geometric, 7x7 raised spa, Tahoe Blue Quartzscapes, 1200 sq ft paver deck (Belgard/Urbana Stone/Danville Beige), Sheer Descent 24", Jandy E Pump 2.0 HP Var Speed, Jdy Heater 400 BTU JXI Natural Gas, Jandy 460 Cartridge Filter
    Apr 2016
    Houston, TX
    208
    nice pool design, ours is 4ft-5.5ft-4ft.... great depths throughout,, I was very demanding on going 3.5-6-3.5 and my PB convinced me to go the other route and im glad he did, now that we have it im sure I would of not liked the 3.5ft... and the 5.5 in the middle is perfect aswell... our whole pool length gets used with different kids in different heights...
    2016 pool build.... 18k gal. freeform style, built in round table, 18" jumping platform, travertine coping upgrade, travertine waterline, peagravel decking, saltwater pool (no spa), Quartzscape blue., 1.5hp Pentair pump, JANDY SWG, 48sqft Pentair DE filter, TFP-100 kit w/speedstir MYPoolBuild
    bdrex28's Avatar
    Jun 2016
    Frisco, TX
    247
    Quote Originally Posted by ap2002 View Post
    we recently decided to go 4' , 5.5', 4' .
    So you're quite happy with that then?
    Brian (Frisco, TX)
    2016 18,250 Gallon IG, Spa, Pentair Intelliflo VS, Pentair Master Temp 400k, , EastyTouch 8/ScreenLogic Surface: Pebblesheen Blue Surf with Abalone, Travertine Coping and Pavers. 3 LED in Pool 1 in Spa. New Frisco, TX Pool Build
    Jun 2016
    Savannah
    30
    The excavation crew is supposed to be here in half an hour! After being rescheduled three times in the past week, we are so ready to get this pool dug!!!
    Here are the before photos! You can't see the outline very well anymore now that the grass has grown a foot in a week!
    May 2016
    fort worth, tx
    123
    Hang on! It's about to get real!!
    Construction began 5/2016. IGF pool. 41' x 21'. Jandy DEV60, Jandy 2hp 2sp pump, Polaris 280 Black Max, Rainbow 320 chlorinator, Jandy JXI 400, Jandy iAqualink, Jandy LED's. 2'x2'x10' rock weeping wall. Dive rock. Tile/Plaster: NPT Silverstone AquaMarine Decking: Stained Stamped Concrete/Stonescapes Aqua Blue with glass beads and abalone. http://www.troublefreepool.com/threa...-Fort-Worth-TX
    Jan 2012
    7,239
    I wish I could come grab some of that grass that's gonna get wasted with the dig.... give my puppies pretty new grass to discolor
    May 2016
    Dallas/TX
    276
    I am doing 3.5-5.5-4.5. It's all about how your PB grades your pool. Mine is pretty much mostly 4.5-5. It's a blip of 3.5. It'll come in handy for the future children.
    Jun 2016
    Savannah
    30
    My boy wanted a front row seat for today's action
    bdrex28's Avatar
    Jun 2016
    Frisco, TX
    247
    haha, great photo! he's definitely got first row seats. Now he just needs a sandwich and some milk
    Brian (Frisco, TX)
    May 2016
    Dallas/TX
    276
    How did the hole hold up with the rain?
  20. Back To Top    #20
    Jun 2016
    Savannah
    30
    They only got a very small portion done on Friday since they didn't start til 2. The pool builder emailed me over the weekend asking how much rain we got. He was worried it would be too muddy and the bobcats would slip too much to finish the dig. It was pretty muddy in some spots but they showed up Monday and I guess it was okay because the majority of the dig was done that day.
    They worked all day from about 7 am to 6 pm.
    On Tuesday they finished up the dig around noon.
    Nothing happened on Tuesday afternoon or Wednesday morning. By early afternoon I was getting very antsy and sent the PB a message to ask when we could expect the next phase to start and he acted like nothing would be happening til early next week! I was bummed. But about an hr later the steel guys showed up! They worked until dark, were back early this morning and then just a couple of hours later all of the equipment and plumbing showed up! It's like crazy town out there right now. It so weird to see so many different people working on so many different things when for three days it was basically the same two guys out there digging.
    I think the odds are good that we could get gunite by Mon or Tuesday!
    ETA: none of these pics really show the raised spa. It's there, it just so hard to get everything in the pics!
