Thread: New Pool Heater Advice
    I need to replace my heater and am considering the Hayward H350FDN Universal H-Series, Low NOx, 350,000 BTU, Natural Gas, Pool and Spa Heater
    1. Are there any other units I should consider looking at?
    2. Does anyone know anything about the quality/reliability of this unit?
    Thanks.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,321
    Re: New Pool Heater Advice
    1. Raypak/Rheem are often recommended.
    2. reliability is very low on the Hayward's from what I've read here. (and costly when they malfunction)
    Dolphin E10 Cleaning Robot.
    Dec 2014
    Houston, Texas
    134
    I like the Sta-Rite/Pentair heater mainly due to the combustion chamber being completely enclosed, keeps pests like mud dobbers and spiders from clogging the burner tubes and gas orifices (we have a ton of them in Houston). Be sure to stay as close to the BTU you have as the new heaters are very picky on gas pressure.
    I do agree with borjis on the Hayward heaters, stay away from them.
    Are there any specific models you might recommend?
    Thanks!
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Raypak for the win! Hayward heaters have a high failure rate on their heat exchangers. I also find the Sta-Rite units have issues as well. I see their blower motor failures, keypad failures, mice chewing wires, and on and on.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
