Results 1 to 7 of 7
Thread: Suggestions for Clearing Up Sunscreen
    Jul 2015
    Oxford, MI
    43
    Thanks to you I am now a total pool snob. I love my clear water. We often have upwards of 10 kids in the pool at a time and on super sunny days the sunscreen seems to melt right off them and cloud up the water. Of course, nobody besides me notices this - they all say it is still clear and fine.
    What do you do to combat the sunscreen that gets into your pool? Float a tennis ball? Nothing?
    So far I just bump up the chlorine to just over my high end based on my CYA and then wait for it to do it's job. Is there something I could be doing to help it along?
    In-Ground pool: 10,000 gallon / vinyl liner /
    Hayward Vari-Flo XL sand filter / Hayward H-series heater
    TF-100 test kit
    JoyfulNoise's Avatar
    May 2015
    13,201
    Re: Suggestions for Clearing Up Sunscreen
    Scum-bug in the skimmer and/or Pig brand oil-only polypropylene absorbent mat floating on the water -
    Matt
    wjr75's Avatar
    Jun 2013
    IL
    836
    Pool Perfect has enzymes that help break the stuff down. I still have a bottle of it that I use a cap full after a big party.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I throw a scum ball in each of my skimmers before a big gathering. Seems to help.
    Isolated Spa - 345 Gallons
    wjr75's Avatar
    Jun 2013
    IL
    836
    I bag of non-chlorinated shock MPS after a party may also help. There was a thread that Chem Geek had suggested it and I sometimes do that also.
    May 2015
    13,201
    If the oils reside in the surface, then mechanical methods (scum bug, etc) are best. If the water is clouded, then you may need to treat chemically. Before investing money in enzymes (which can cause excess FC demand) or expensive non-chlorine shock (which can register falsely as CCs on your FAS-DPD test), it is simplest to just raise your FC up to a higher level (maybe a 20% FC/CYA ratio) for 24 hours and see if that helps to clear it.
    Matt
    Jul 2015
    Oxford, MI
    43
    Great advice!
    Since I have the chlorine on hand, I'm going to start with that as my cheapest method and bump it up a little more than I had been. But the scumbugs look cool and I might just have to find one.
    Thank you!
    TF-100 test kit
