Results 1 to 8 of 8
Thread: Blue to Thick Green
    Jun 2016
    Westerville/oh
    4
    Blue to Thick Green
    I am ready to give up on being a pool owner. My pool was the prettiest blue and within 3 days it was green. I was told it is because I left the solar cover on. Now it is a thick dark green. I have shocked it over and over. I have added chlorine bleach and it is still saying my FC is low. I am now told I need to flock it or I will never get the algae out. I have spent over $100 in chemicals. I really had hopes of celebrating the 4th in my pool.
    28' Round above ground pool w/vinyl liner, approximately 26,000 gallons, Hayward Sand Filter, Columbus, Ohio
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: Blue to Thick Green
    No, it got green because the FC went too low.
    Step 0. Stay out of the pool store.
    Step 1. Get a good test kit. TF-100 is the best (see signature) Taylor 2006c will do as well.
    Step 2. Add a half gallon of bleach a day with the pump running until your test kit comes.
    Step 3. Read this Pool School - ABCs of Pool Water Chemistry
    Step 4. Let us know what your first test is when your kit comes.
    And welcome to TFP
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jun 2016
    Westerville/oh
    4
    Thank you. This forum is great. After reading other posts, I ordered the test kit you just mentioned.
    I have filters at the bottom of my pool as well. I closed the valve to them because it seems that is just sucking algae and then blowing it back in. Should I leave them closed?
    Jan 2012
    'burbs of Augusta, Georgia
    7,306
    no, open the filter valve. You want all that chlorine to reach every nook and cranny in the pool. Brush it daily too.
    Which kit did you order and from where? Do you have an idea of when it will arrive?
    Jun 2016
    Westerville/oh
    4
    I ordered the FAS-DPD chlorine test kit. It should be here by Tuesday at the latest due to the holiday.
    sekinkead's Avatar
    Jun 2016
    Centerburg, OH
    31
    Hey, you're not far from me. I work in Westerville but live out beyond Johnstown. I'm having trouble with cloudy water and also got the TF-100. I ordered it Monday of this week and I received it on Wednesday. So if you ordered it today, maybe you will get it Saturday. Good luck!
    27' Round, 52" Walls, 17,100 gal, AG, Hayward S180T Sand Filter, Hayward Power-Flo Matrix 1.5 hp pump. TF-100 test kit/speedstir
    Jun 2016
    Westerville/oh
    4
    How long should I leave my pump on? Should it stay on until the pool is clear or should I have it off for the stuff to settle? Also, what is flocking?
    Jan 2012
    7,306
    When SLAMing a pool you want the pump to run continuously so that you're filtering.
    Floc is a chemical we don't often recommend. It makes stuff stick together and fall to the bottom of the pool (supposedly) so that it easier to vacuum out.
